Help
Help
Hey How's it going,
I just bought an 06 s2k, it was in an accident and got hit in front right side. My problem is that all the lights on the cluster stay on ( vsa, powersteering, abs, "!", brake, airbag ) when you turn it on. Everything works on the cluster except for the rpm. I thought it was something electrical so I checked the wires but they look good. I was thinking maybe that little box by the battery? And my powersteering isn't working either. Any help would b appreciate it.... thanks in advance Jesse
... got the vsa erased the rest are still the same and no rpm working. ..... help plz
Re: Help
Thanks for taking ur time and checking my thread. I went through all the wire harness, fuse box, and wires look good, fuses look good the harness looks good. I went through my abs sensors and the right back side is missing. I've read up that might need to take or to the dealer to get something reset After I put that sensor. I took the car to get it scanned and this is what came up. Any help is appreciated it. Thanks.
☆Fault Codes☆
*12-1: Open Circuit Or High Resistance In Passenger Side Impact AirBag Module.
*15-1: Faulty OPDS Unit Or OPDS Not Initialized.
*16-1: Right Rear Wheel Sensor Failure. " I'm missing That Sensor"
*23-1: Malfunction In Knock Sensor Circuit.
*27-1: Steering Angle Sensor Failure " VSA & "!" Lights"
*61-1: Battery Voltage Failure
*83-1: ECM/PMC Relation Failure.
*84-1: Sensor Logic Failure
☆Fault Codes☆
Re: Help
the wheel speed sensor, even slightly off, is very important to the 06+ it's what helps VSA determine when to trigger traction control protocols
get the wheel speed sensor replaced and then make sure your knuckles and lower control arms aren't bent
shot_them_all
Honda Civic (2001 - 2005)
12-06-2011 04:43 PM
