Honda S2000 Honda S2000
Does the S2000 use a timing belt or a chain?
Old 11-29-2002, 10:01 PM
OneThirtyEight's Avatar
Default Does the S2000 use a timing belt or a chain?
S2000 use a timing belt or a timing chain?
Old 11-29-2002, 10:07 PM
New User
JDM nerbie's Avatar
Default Re: Does the S2000 use a timing belt or a chain? (97blackteg)
chain
Default Re: Does the S2000 use a timing belt or a chain? (JDM nerbie)
chain
omg im buying one, thats all there is to it now.
Old 11-30-2002, 12:57 AM
BoYgUaN's Avatar
does it really
i swore hondas use belts
Old 11-30-2002, 06:50 AM
2K_TEG's Avatar
Default Re: Does the S2000 use a timing belt or a chain? (BoYgUaN)
https://honda-tech.com/zerothread?id=345315
chain
Old 12-01-2002, 09:16 PM
-Darren-'s Avatar
Default Re: Does the S2000 use a timing belt or a chain? (2K_TEG)
what are the advantage's of having a chain driven engine as opposed to a timing belt.
Old 12-01-2002, 10:31 PM
Trac226's Avatar
Default Re: Does the S2000 use a timing belt or a chain? (star&buc)
The reason why oems used belts was cause they were quieter. Guess they solved the problem.
Old 12-01-2002, 11:50 PM
DsITR's Avatar
Default Re: Does the S2000 use a timing belt or a chain? (Trac226)
w/the s2k's high *** redline, a chain is neccessary.
The advantage of a belt is less parasitic hp loss...guess they figured that out too w/the s2k's 2.0 making 240hp
[Modified by dsludefosho, 1:51 AM 12/2/2002]
Old 12-02-2002, 07:02 AM
-Darren-'s Avatar
Default Re: Does the S2000 use a timing belt or a chain? (dsludefosho)
so why does the jdm type r have a belt instead of a chain? it rev's to 9k rpm to.
Old 12-02-2002, 07:25 PM
-Darren-'s Avatar
Default Re: Does the S2000 use a timing belt or a chain? (S2quick4U)
oh, ok thanks
Old 12-04-2002, 10:31 PM
Razor's Avatar
good thing it has a chain, now u dont have to worry about changing a 'belt' every 90k miles.
do the chains last as long as your car or u still have to change them periodically?
Old 12-04-2002, 10:47 PM
-Darren-'s Avatar
Default Re: Does the S2000 use a timing belt or a chain? (Razor)
i would like to know this also
Old 12-04-2002, 10:55 PM
Lsos's Avatar
because the JDM Type R's dont have as much torque and dont produce 240 hp
I don't think there's much of a relation between the power/ torque of an engine and the stresses on the timing belt.
Old 12-05-2002, 09:09 AM
Lsos's Avatar
I can see the speed of the crankshaft increasing inertial stresses on the timing belt.
Other than that, say you put a huge supercharger or turbo on an engine, increasing the power by 10x. How would that change how much force it takes to turn a camshaft or water pump? That's where the stresses on the belt come from.
Old 12-10-2002, 01:09 PM
Chugger's Avatar
Default Re: Does the S2000 use a timing belt or a chain? (Lsos)
yup chain
chains dont slip
just stretch over long periods of time
some older domestics use chains and some new ones
i wonder if toda will need to upgrade to a strnger chain for there cams like they recommend for the b-series
Old 12-15-2002, 11:05 AM
teg
teg's Avatar
DC2-R has 8400 rpm at 200hp.(jdm spec)
DC5-R has 8400 rpm at 220hp.(jdm spec)
airikkCRX
04-02-2010 08:29 AM
tricura
211
09-30-2009 08:52 AM
pbizzlegsr
07-05-2004 10:41 PM
dimsum
12-03-2002 11:28 PM
Quick Reply: Does the S2000 use a timing belt or a chain?
