Honda S2000 Honda S2000
Can't get my fing maint req'd light off...
Old 10-08-2004, 05:38 PM
GroovyNeilNeil's Avatar
Default Can't get my fing maint req'd light off...
Does anybody know how to do this? The book says "To reset the maintenance required indicator, turn the ignition switch to the LOCK position, then press and hold the trip meter reset button until the indicator resets."
I did this...however the maint req'd light is still on and I have no clue what I'm doing wrong. Anybody have a better way to explain it than in the Honda Owners manual. It's a 2000 S if that makes a difference.
Thanks in advance.
(I don't want to use the search)
Old 10-08-2004, 06:21 PM
EnigmaofS2K's Avatar
Default Re: Can't get my fing maint req'd light off... (GroovyNeilNeil)
Keep trying! It may take more than a few times to get it right. Mine is also flashing, but I'm too lazy to look in the manual to see how to make it disappear.
Old 10-08-2004, 07:31 PM
AWD: Jeff's Avatar
Default Re: Can't get my fing maint req'd light off... (EnigmaofS2K)
u just need to hold the button a little bit longer, i do it all the time.
Old 10-08-2004, 07:46 PM
Default Re: Can't get my fing maint req'd light off... (Eh2 to Ap1)
You're supposed to hold the button that says "Trip" right? How long is long enough? 1 minute...2 minutes...? The ignition is not supposed to be on, correct? Is there a beep for me to know that it turns off or should I just guess?
Old 10-08-2004, 09:35 PM
JS2K's Avatar
that hold of the button sually works but you have to do it for a little while.
on my it was some of a painin the *** to it.
Old 10-09-2004, 07:00 AM
tmkpres's Avatar
Default Re: Can't get my fing maint req'd light off... (JS2K)
I thought that you put it on the lock position hold the trip themturn the ignition to the on position. Then wait till the light goes off !?
Old 10-09-2004, 02:02 PM
Default Re: Can't get my fing maint req'd light off... (tmkpres)
Yep, that's how you do it. Went to Honda dealer, had them show me how. Also had my taillights replaced due to a recall. Rock out.
Old 10-09-2004, 04:50 PM
bryant's Avatar
Just did it on my car.
Put key in. Hold trip button down. Turn the key all the way. Keep holding trip button. Wait for Mait. Req. light to go off. Let go of trip button. Turn car off.
1stcivic
10
01-24-2006 07:50 PM
edger8cer
07-21-2005 06:03 AM
hookedonvtec
07-20-2004 08:22 AM
B18CXr
01-24-2004 06:51 AM
lx98
04-27-2003 10:13 PM
Quick Reply: Can't get my fing maint req'd light off...
