Windshield wipers not moving
Old 05-27-2009, 10:21 AM
MileHigh's Avatar
Icon6 Windshield wipers not moving
my sister's 99 SH wipers stop moving, could it be the motor gone bad?
The water sprayer still works, but could it be the switch?
I have my 4th gen manual, is the 5th gen wiper system similar?
Old 05-27-2009, 01:03 PM
Hawkze_2.3's Avatar
Default Re: Windshield wipers not moving
Could be the motor, switch, relay, fuse, etc.. You might have to start doing a little detective work if it's not anything obvious.
Old 05-27-2009, 04:01 PM
MileHigh's Avatar
well, after I parked it in the garage, I can still hear the wiper motor running. hmmm so what can be wrong?
Old 05-27-2009, 06:06 PM
Hawkze_2.3's Avatar
Motor still running eh? Probably a problem with the motor itself then... If it has power and it's not doing anything then it probably has a failure on the inside.
Old 05-27-2009, 07:52 PM
boostedmonkey's Avatar
If you can still hear your motor running, then the motor is fine. The wiper arm linkage is broke. Pop your wiper cowl and check rod a and b. I'll be the one that links to the motor is either popped off because the plastic socket broke, or the whole rod end broke. I just replaced the rod a and b in an 01 Accord for the same thing.
Old 05-28-2009, 06:49 AM
ljcandmwd's Avatar
I am having a similar problem but mine are not flush like they used to be. They are moving fine, but just won't lay flush. My sprayers quit working too.
mkfrl
11-14-2018 04:45 PM
dogbiscuit
Honda CR-V & Element
13
11-11-2013 04:15 AM
Olias
11-22-2008 02:36 PM
nbcivic
10-05-2007 01:14 AM
daidilus
12-10-2004 04:16 PM
Quick Reply: Windshield wipers not moving
