will ABS light on fail smog test in Ca - Honda-Tech
Old 05-04-2005, 10:58 PM   #1
plutohk's Avatar
Default will ABS light on fail smog test in Ca
Can my lude pass smog test with ABS light on or I have to get it fixed before testing? The code indicates that ABS pump motor has gone bad.
Thanks
plutohk is offline   Reply With Quote
Old 05-05-2005, 08:21 AM   #2
Default Re: will ABS light on fail smog test in Ca (plutohk)
Should not, but not sure. Why don't you call your local testing center
fs
Filthy Focker! is offline   Reply With Quote
srs light slimjimming6688 Honda Civic / Del Sol (1992 - 2000) 9 02-03-2009 10:58 AM
ABS & Brake Lights thatonejewishguy Honda Accord (1990 - 2002) 3 03-04-2006 07:00 AM
This question is for cali people (smog related) SOLO1racer Honda Accord (1990 - 2002) 2 01-27-2005 01:36 AM
ABS light Shaun92lude Honda Accord (1990 - 2002) 3 12-08-2004 08:11 AM
Smog Check in Cali .. Test Only Rocks Honda Civic / Del Sol (1992 - 2000) 3 10-18-2004 12:49 PM
Tags
abs, asb, brake, ca, california, car, check, fail, failed, light, pass, passing, sensor, smog, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
