WHERE IS THE TRANSMISSION FLUID PLUG?
Re: WHERE IS THE TRANSMISSION FLUID PLUG? (4bidden)
is that easier? i know it can be a pain filling it in the plug i listed but that can easily be fixed using something similar to a grease gun (pulls the fluid in then you spray it in the tranny) or a funnel.
You still open the fill plug to be sure when you're filled up right? coz you're only supposed to fill up to that point, correct?
Re: WHERE IS THE TRANSMISSION FLUID PLUG? (93preludevtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludevtec »</TD></TR><TR><TD CLASS="quote">thats incorrect andy. there is one, hold on i'll find a pic. </TD></TR></TABLE>
Hmmm, thanks for the pic. People told me that there wa sonly one plug that you drain and fill from.
Thanks
Thanks
the drain plug is 10 and the fill plug is 14</TD></TR></TABLE>
The drain plug is easy to differentiate from the rest because it is a square hole in the middle of a perfectly rounded bolt. You have to shove a 1/2 drive in there to take it out.
Re: WHERE IS THE TRANSMISSION FLUID PLUG? (preluda92)
The pic isnt working. Can someone please show me the pic? I need to know where my fill plug on my S1 tranny is. Thanks
Re: WHERE IS THE TRANSMISSION FLUID PLUG? (94Vtecluder)
Come on guys, crawl under your car and take a look. There are only two plugs/bolts in the side of the transmission. The lower one is the drain, the upper one is to fill. Pull the bottom one to drain it. When the oil is done running out, put that one back in, and take the upper one out. You need to use a hose probably with a funnel, fill until it starts to run out, a little over 2 quarts.
Edit: Don't fill the transmission using that breather hole on the top of the tranny, you may get too much or too little in there using that. It's a breather, not a filler.
Re: WHERE IS THE TRANSMISSION FLUID PLUG? (94vtecmn)
Okay, since I couldnt find any pics anywhere that were decent. I just went by the fact the the fill bolt was a 17mm and started sizing. I used two funnels to fill my fluid back up (to make a bend...I dont have any hose). Worked like a charm. Now my whinig noise is gone, but my tranny is still leaking fluid where the flywheel is. Any suggestions on that?
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluda92 »</TD></TR><TR><TD CLASS="quote">
The drain plug is easy to differentiate from the rest because it is a square hole in the middle of a perfectly rounded bolt. You have to shove a 1/2 drive in there to take it out. </TD></TR></TABLE>
actually a 3/8 drive will work,
not everybody has a 1/2 drive anyway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keith »</TD></TR><TR><TD CLASS="quote">Drain bolt is the clean broze bolt and fill bolt is the rusting bolt on the top left side -
is that a b16 tranny?
Re: WHERE IS THE TRANSMISSION FLUID PLUG? (SKDRCR)
yeah mine was a 3/8 drive, and mine isn't bronze. . but to fill the tranny i used the vent hole located on the top, and when fluid started coming out of the fill hole that your supposed to use, then you have enough fluid.
Andrew14
21
06-28-2010 01:12 PM
