The "Where Can I get" this thread. - Honda-Tech
Old 08-21-2005, 09:44 PM   #1
PrecisionH23a's Avatar
Default The "Where Can I get" this thread.
Everyday I see another "Where can I find" something thread.
This will be the official thread to ask where you can find something. Please respond with answers and I will later sift through the info and make one giant thread of resources for hard to find parts/components.
Let's get this ball rolling
p.s.
This is NOT a wanted bad thread. Make a post saying "I need XXX, hit me up" and you will be docked points.
This is not also a thread for WHERE CAN I FIND THIS FOR CHEAP.
PrecisionH23a is offline   Reply With Quote
Old 08-21-2005, 10:03 PM   #2
mgags7's Avatar
Where can you get:
Adapter plate for the sh block to fit a regular midshaft??
Plastic js racing replica intakes
mgags7 is offline   Reply With Quote
Old 08-22-2005, 05:49 AM   #3
Default Re: (mgags7)
Q) Where to find Balance Shaft Delete Kits?
A) http://www.kaizenspeed.com
Honda318dx is offline   Reply With Quote
Old 08-22-2005, 09:58 AM   #4
The Weather Man's Avatar
Q) Where can I find block guards?
A) http://www.honda-performance.com
The Weather Man is offline   Reply With Quote
Old 08-22-2005, 12:51 PM   #5
rockna92quelude's Avatar
i had the same problem and made a adapter bracket to bolt the shaft to the sh block from a pice of 1/4 plate steel measured like 4 by5 and measured the holes in the shaft bracket and then tapped those holes then drill the holes is the plate for the block... insert shaft to trans and then slide plate in to be bolted into place.. i was told that it would never work but its been in there for almost 15000 miles and ALOT of dragstrip time and no problems yet...
rockna92quelude is offline   Reply With Quote
Old 08-22-2005, 01:32 PM   #6
Shahigabothin's Avatar
Default Re: (rockna92quelude)
Does anyone kno where i can get this front lip. I cant seem to find it any where, if someone knows where i can get it please post a link.
Modified by Shahigabothin at 3:29 PM 8/22/2005
Shahigabothin is offline   Reply With Quote
Old 08-22-2005, 06:54 PM   #7
Geeq's Avatar
Default Re: The "Where Can I get" this thread. (PrecisionH23a)
Where can I get....Or do they make?
The mounts for your Stock or OEM style hoods that can be lifted where the hood meets the windshield.
I've seen it Searching for Pics of cars. It's a JDM style that you don't see here in the US...so I've heard. It creates a sort of Cowl induction by lifting the hood up an inch or two still using your stock hood.
Does anyone klnow if there are any Kits or is it just custom fabrication???
Geeq is offline   Reply With Quote
Old 08-23-2005, 12:44 AM   #8
upallnite's Avatar
Default Re: The "Where Can I get" this thread. (Geeq)
I think I have seen what you are talking about. The car I saw with it just did it his self with longer bolts and washers as spacers. You can't raise it much if you want the latch to still work right.
upallnite is offline   Reply With Quote
Old 08-24-2005, 11:34 AM   #9
LudeyKrus's Avatar
Ace Hardware/Fastenal. Get longer bolts and a handful of washers and go to town.
LudeyKrus is offline   Reply With Quote
Old 08-25-2005, 03:14 PM   #10
space cadet
Shakes's Avatar
JDM? if anything its SoCalDM.
its a metal dowel cut about 3/4 of an inch or however far you want. however be careful, 1 - it looks like **** on ludes, 2 - its easy to break a window (done it myself), however it does let tons of heat out of the engine bay.
Shakes is offline   Reply With Quote
Old 08-26-2005, 07:50 AM   #11
IAluder95's Avatar
where can i get a Kit to use a B series Tranny?
IAluder95 is offline   Reply With Quote
Old 08-26-2005, 09:05 AM   #12
matix's Avatar
Default Re: (IAluder95)
Q) Were can I get a adapter plate to mount a D-series tranny on a h22?
A) http://www.bisimoto.com/wst_page10.html
matix is offline   Reply With Quote
Old 08-26-2005, 03:52 PM   #13
PreludeWhore's Avatar
Okay here it goes...flame suit on...WHO makes the side skirt? Where can I get them from..etc??? Thanks in advance!
DF
PreludeWhore is offline   Reply With Quote
Old 08-26-2005, 09:36 PM   #14
LudEnthusiast's Avatar
Looks like a VIS Mugen sideskirt to me.
LudEnthusiast is offline   Reply With Quote
Old 08-27-2005, 04:47 PM   #15
jg86hawk's Avatar
Default Re: (LudEnthusiast)
The picture you posted is named "mugensides"
jg86hawk is offline   Reply With Quote
Old 08-27-2005, 10:42 PM   #16
I'm hosting this picture (I got somewhere here or PO.com) I don't know who makes it, but it sure doesn't look like the real mugen.
Old 08-28-2005, 08:01 AM   #17
clemsoncb7's Avatar
Default Re: (PreludeWhore)
(Q)where can I find a deck plate/torque plate for honing?
(A)www.f22parts.com
(Q)where can I find JDM fogs, headlights, corners, etc.?
(A)www.passwordjdm.com
(Q)Where can I get a beef and bean burrito?
(A) Taco Bell, duh
clemsoncb7 is offline   Reply With Quote
Old 08-28-2005, 10:09 AM   #18
Jordans95si's Avatar
Default Re: (maxvtec7500)
where can i get some ngk spark plug wires and plugs for a good price
Jordans95si is offline   Reply With Quote
Old 08-28-2005, 08:07 PM   #19
Paul H22A4's Avatar
NGK Spark Plugs and Wires
http://www.importrp.com/home.php
Paul H22A4 is offline   Reply With Quote
Old 08-29-2005, 01:03 PM   #20
The Birdman's Avatar
where can you find some polyurethane aftermarket motor mounts?
The Birdman is offline   Reply With Quote
Old 08-29-2005, 04:38 PM   #21
Paul H22A4's Avatar
Default Re: The "Where Can I get" this thread. (jd3jdm)
Quote:
inlinefour.com
Old 08-29-2005, 05:48 PM   #22
Default Re: The "Where Can I get" this thread. (Paul H22A4)
If you are talking about the energy suspension ones, they aren't mounts, just inserts. I'm looking for the whole mount.
Old 08-31-2005, 07:01 AM   #23
Paul H22A4's Avatar
They sell both there. Mounts and Inserts
http://www.enjoracing.com/engine_mounts_swap.html has some.
Old 08-31-2005, 07:09 PM   #24
getbig's Avatar
Q) Carbon Fiber Cooling Shroud (Above the radiator)?
getbig is offline   Reply With Quote
Old 08-31-2005, 07:40 PM   #25
dand39's Avatar
Where can I find an intake chamber for a 4th Gen w/ H22?... provided there is one...
dand39 is offline   Reply With Quote
Ass$nyper + ZTwentyH8's Sexting Thread everyone else stay out ZTwentyH8 General Discussion and Debate 2701 03-10-2017 07:47 AM
Rules, Thread Titles, Car Information, Searching, Trial Users, and Picture Posting Former User Honda Civic / Del Sol (1992 - 2000) 3 10-01-2012 11:06 AM
Tags
1988, aftermarket, body, cheap, customized, del, fabrications, georgia, h22, headphones, motor, mounts, parts, prelude, sol, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
