Differance between JDM H22 Intake manifold and USDM H22a4 IM?
Old 04-19-2005, 11:39 AM
Boarderx192's Avatar
Default Differance between JDM H22 Intake manifold and USDM H22a4 IM?
Whats the differance between the JDM H22 Intake manifold and a USDM H22a4 intake manifold? I know the injectors are differant but what else is? Is the Throttle body the same?
Old 04-19-2005, 11:51 AM
98TypeSH's Avatar
Default Re: Differance between JDM H22 Intake manifold and USDM H22a4 IM? (Boarderx192)
pretty sure the injector is the only difference. TB and everything else should be the same. There may be a different mounting point on the bottom of the IM for the older H22A motor vs a new style H22A4 ( all the atts provisions and stupid ****) I have both manifolds and thats the only possible difference i see.
Old 04-19-2005, 05:18 PM
prelittlelude's Avatar
nothing other than injectors and the fuel rail is different but that doesn't count as part of the mani,
if your asking if it will bolt up yes is the answer, the TB should be the same as well
Old 04-21-2005, 10:30 AM
Default Re: Differance between JDM H22 Intake manifold and USDM H22a4 IM? (prelittlelude)
I bought a JDM intake manifold for my 98 H22a4. I know that I need the 98 Injectors, but can I use the JDM fuel rail?
Old 04-25-2005, 07:40 PM
92_civic's Avatar
does anyone know the size of the jdm intake manifold injectors
Old 04-25-2005, 08:37 PM
Drag-Accord's Avatar
Default Re: Differance between JDM H22 Intake manifold and USDM H22a4 IM? (92_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_civic &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know the size of the jdm intake manifold injectors </TD></TR></TABLE>
345cc
Old 12-24-2005, 10:30 PM
Dueceification's Avatar
If its a OBD1 JDM h22 then the throttle bodies will be different. The size should be the same but the MAP sensor locations will be different. The OBD1 uses a firewall mounted MAP sensor while the OBD2 motor uses a TB mounts MAP sensor.
G.C
04-06-2008 12:55 PM
DSoDry
10-29-2005 05:55 AM
LvN
01-30-2005 10:13 PM
kkw103
06-02-2004 07:44 PM
jdmcivicferio
04-20-2004 12:02 PM
Quick Reply: Differance between JDM H22 Intake manifold and USDM H22a4 IM?
