what would cause oil inside intake manifold - Honda-Tech
Old 10-24-2009, 07:54 PM   #1
Pullig's Avatar
Default what would cause oil inside intake manifold
Well i have a jdm h22a .. Got it from HMO abt a year ago it runs great and compression is great... well i took off my intake manifold the top part because i wanted to remove the iab plate.. Well what i noticed was pools of oil in each port ... I do have a new PCV valve so it shouldnt be that but possibly? what else could be causing this oil in my intake it just doesnt seem right to me ?
Pullig is offline   Reply With Quote
Old 10-24-2009, 09:42 PM   #2
Linh.'s Avatar
Default Re: what would cause oil inside intake manifold
Linh. is offline   Reply With Quote
Old 10-26-2009, 07:19 PM   #3
jprelude92's Avatar
you have too much blow by your gonna need to put new rings on those pistons.
jprelude92 is offline   Reply With Quote
Old 10-26-2009, 07:34 PM   #4
Pullig's Avatar
Quote:
yeah how would it get into the intake like that? The motor is strong as hell .. compression is great all the way across even a leak down showed good numbers... it doesnt even smoke ...
Old 10-27-2009, 12:33 AM   #5
jonbar87's Avatar
pcv
jonbar87 is offline   Reply With Quote
Old 10-27-2009, 06:55 AM   #6
PirateMcFred's Avatar
PCV + blow by
PirateMcFred is offline   Reply With Quote
B vtec rocker arm pad machining Pullig Engine Machining & Assembly 9 11-22-2015 09:58 AM
Prelude Innovative Motor Mounts and 2.5in Full Exhaust Pullig For Sale 3 08-27-2010 09:01 PM
energy susp. motor mnt inserts Prelude and stock mounts Pullig For Sale 0 10-19-2009 05:30 PM
D16z6 transmission parts cheap!! 2.5inlet Muffler Pullig For Sale 0 10-19-2009 05:01 PM
NRG torque damper Accord/Prelude Pullig For Sale 1 02-28-2009 10:29 AM
Tags
2000, 23, 91, 92, accord, blowby, civic, h22a, honda, inside, intake, manifold, oil, recommended, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
