What is the Green Key Light mean? - Honda-Tech
Old 02-08-2007, 03:41 PM   #1
APEXI Si's Avatar
Default What is the Green Key Light mean?
What dose the green key light mean? My car has been recently stalling on me and i wonder if that has anything to do with it.
APEXI Si is offline   Reply With Quote
Old 02-08-2007, 03:53 PM   #2
roller3804's Avatar
the green keylight is the imobilizer.
roller3804 is offline   Reply With Quote
Old 02-08-2007, 03:56 PM   #3
APEXI Si's Avatar
Default Re: (roller3804)
what does that do. My key is NOT a stock honda key. Could that be part of my problem.
Old 02-08-2007, 04:00 PM   #4
roller3804's Avatar
i can't remember if the 5thgens have keys with chips in them.. sorry man maybe a 5thgenner will chime in
Old 02-08-2007, 04:14 PM   #5
DfwBB6's Avatar
Quote:
yes my 5th gen key does have a chip
DfwBB6 is offline   Reply With Quote
Old 02-08-2007, 04:34 PM   #6
britishdude's Avatar
Default Re: What is the Green Key Light mean? (APEXI Si)
5TH gen had a Honda recall on the ignition switches, if you havn't had it done you can book into the dealers for a new ignition switch fitted for free, under a safety recall because they kept cutting out.
britishdude is offline   Reply With Quote
Old 02-08-2007, 04:55 PM   #7
APEXI Si's Avatar
Default Re: What is the Green Key Light mean? (britishdude)
my car is a salvage title and they said they would not replace for free. Is that a bunch of **** or what
Also, Is that green key light suppose to come on when I first turn the key and when I take the key out?
Old 02-08-2007, 06:12 PM   #8
KEVLARsh's Avatar
my 5th gen lights up when i start car, and after I shut car off, if car stalls that light isn't on, is yours on when it stalls???
KEVLARsh is offline   Reply With Quote
Old 02-08-2007, 06:33 PM   #9
APEXI Si's Avatar
Default Re: What is the Green Key Light mean? (KEVLARsh)
There is one solid flash when I start it and 4 flashes after it stalls and when I shout the car off. When It stalls it is like I just turned the key back.... but didn't
Old 02-08-2007, 06:55 PM   #10
PrettyLude's Avatar
yea, it has something to do with the immboliser, are you using the right programmed key? if you are you might be experiencing problems with the ignition switch
PrettyLude is offline   Reply With Quote
Green key light flashes AFTER I turn the ignition off Kytti Honda Civic (2001 - 2005) 1 06-19-2015 11:41 AM
1998 HONDA ACCORD EX, ONLY STARTS WHEN cmperez Honda Accord (1990 - 2002) 6 04-03-2008 09:36 AM
just askin about the green arrow in my hatch smokerz212 Honda Civic / Del Sol (1992 - 2000) 9 03-09-2006 07:40 PM
Flashing key light...car wont start! purehonda Acura Integra 7 01-02-2006 04:47 PM
maintenance light rob_honda Honda Accord (1990 - 2002) 7 02-22-2005 05:43 PM
Tags
08, 2002, civic, display, flashed, flashing, green, honda, key, light, mean, odyssey, prelude, solid, stall
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
