What is an EVAP emission 2 way valve? - Honda-Tech
Old 01-16-2003, 09:40 PM   #1
Jonathan_ED3's Avatar
Default What is an EVAP emission 2 way valve?
On Preludes, this sensor is hooked up to one of the nipples coming off from the EVAP cannister.
I need to know what exactly this is so I can figure out the vacuum wiring to put it into my civic.
Can anybody take a pic of it? It's nothing on the engine...it's the one nipple that doesn't go to the engine from the cannister.
I need to know if it's just a valve, or if it's an actual sensor that needs wiring to go with it.
If it's a valve....that'd be great! I can just hook it inline!
But if it's got wiring...I've got no clue what I'll do about it.
Anyway, any help will be greatly appreciated. TIA
Jonathan_ED3 is offline   Reply With Quote
Old 01-16-2003, 10:23 PM   #2
Default Re: What is an EVAP emission 2 way valve? (hot_EG)
come on guys!
I don't have $60 to buy a manual
Old 01-16-2003, 11:01 PM   #3
anyone?
Old 01-16-2003, 11:19 PM   #4
743
743's Avatar
i cant help you but i just figured i'd let you know that you signature rocks nads. good luck.
743 is offline   Reply With Quote
Old 01-16-2003, 11:28 PM   #5
Default Re: What is an EVAP emission 2 way valve? (-SevenFourThree-)
Thanks bro
for the bump
Old 01-17-2003, 02:16 PM   #6
C'mon!
Somebody HAS to know this.
At least scan me some pics of the manual and let me figure it out!
I've got scans of most of the actual vacuum system...but it doesn't continue over to the EVAP Two Way Valve...
Old 01-17-2003, 02:52 PM   #7
satan_srv's Avatar
Because the evaporated fuel goes both ways. the fumes that evaporated into your charcoal canister are sucked back into the tank for combustion when you drive the car.
There is a sensor that determines that the purge is taking place, or else you throw a code.
[Modified by satan_srv, 5:53 PM 1/17/2003]
satan_srv is offline   Reply With Quote
94 honda del sol jdm b16 swap (evap canister) smokescreen160 Honda Civic / Del Sol (1992 - 2000) 4 01-05-2017 10:23 PM
EVAP Smog Questions B17A Engine Colin Tech / Misc 6 05-13-2009 05:31 PM
skunk2 intake manifold evap ? dx2sicrx Tech / Misc 1 05-29-2008 09:20 PM
d16y8 oil catch can/cannister hose connection? BigMoneyP Forced Induction 1 02-04-2006 09:30 PM
Removed Evap Cannister, what to do with fuel vapor line? fastrunner Forced Induction 5 06-09-2005 08:45 PM
Tags
2001, 2002, 94, acura, civic, emission, emissions, evap, for, honda, integra, prelude, twoway, valve, vavle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
