what dose the the"BRAKE LAMP" mean???
Old 05-08-2007, 07:56 AM
ceyazzie's Avatar
Default what dose the the"BRAKE LAMP" mean???
My BRAKE LAMP light comes on when the car moves... whats that light for???? do i have a problem??
Old 05-08-2007, 07:59 AM
AndyD's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (ceyazzie)
Does your car have ABS? I think it is an ABS error.
Get the code. Know how to get the code?
Before you do that though, have someone push the brake pedal to make sure all of your brake lights are working.
Old 05-08-2007, 08:01 AM
gavzter's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (AndyD)
it means you have a brake light out
Gavz
Old 05-08-2007, 08:08 AM
ceyazzie's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (gavzter)
ohh. i think tha third brake light is out??? i need to check.
Old 05-08-2007, 11:36 AM
royalfelix's Avatar
also ur emergency brake can be on OR.... was my problem u could be low on brake fluid.
Old 05-08-2007, 03:27 PM
mattsnooz's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (royalfelix)
yeah, could be the rear window break light.
Old 05-08-2007, 04:16 PM
mkazm83's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (mattsnooz)
Low on fluid.
Old 05-08-2007, 04:20 PM
TheWalrus's Avatar
youre probly low on brake fluid...if its a brake light out, itll come on the first time you step on the pedal, but if it flickers when youre taking turns and *****, check the fluid level and for pad wear
Old 05-08-2007, 05:52 PM
sivikvtec's Avatar
Default Re: (TheWalrus)
I though the parking brake light came on when you were low on fluid. The Brake Lamp light is for bulb failure. It randomly comes on every now and then on my car.
Old 05-08-2007, 06:13 PM
InvaderTrax's Avatar
The light labeled Brake Lamp only comes on when you have a brake light out. The Brake light will come on if your parking brake is up (or bad sensor), or if you are low on brake fluid (again, or bad sensor). The ABS light will come on if you have a problem with your anti-lock brake system
Old 05-08-2007, 11:51 PM
gavzter's Avatar
Default Re: (InvaderTrax)
as said - it's the PARKING BRAKE / HAND BRAKE light that will flash on or stay on when you're low on brake fluid.
the BRAKE LAMP light should simply mean you have a brake light out.
However.. on my old 4th gen, all three lights: brake lamp, parking brake and abs light came on when I had a brake lamp fail
Gavz
Old 05-08-2007, 11:54 PM
P13_mein's Avatar
fix your rear brake lamp(s)
Old 05-09-2007, 04:38 AM
manbearpig's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (P13_mein)
If they're all working, just pull the bulb. I rewired my led spoiler (it was cut when i got the car) and ever since then, it's been on. Even though all 3 lights work fine.
Old 05-09-2007, 06:10 AM
Yield's Avatar
I was getting the "brake lamp" light even though all my lights were working properly. I just changed my rear pads and it went away... whatever that means!
Old 05-09-2007, 07:19 AM
NtheWorks's Avatar
same thing happens on mine. My right front rotor is pretty messed up though and I have it in my garage just havn't done it yet. Does the car really sense when your rotor or pads are bad while you're moving and not stepping on the brake?
Old 05-09-2007, 07:30 AM
mkazm83's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (NtheWorks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yield &raquo;</TD></TR><TR><TD CLASS="quote">I was getting the "brake lamp" light even though all my lights were working properly. I just changed my rear pads and it went away... whatever that means!
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NtheWorks &raquo;</TD></TR><TR><TD CLASS="quote">same thing happens on mine. My right front rotor is pretty messed up though and I have it in my garage just havn't done it yet. Does the car really sense when your rotor or pads are bad while you're moving and not stepping on the brake?</TD></TR></TABLE>
The car "knows" because as your pads wear the piston pushes out. As it pushes out, the fluid level decreases. When its decreased below a preset level, the brake light tuns on.
Old 05-09-2007, 07:35 AM
NtheWorks's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (mkazm83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkazm83 &raquo;</TD></TR><TR><TD CLASS="quote">
The car "knows" because as your pads wear the piston pushes out. As it pushes out, the fluid level decreases. When its decreased below a preset level, the brake light tuns on. </TD></TR></TABLE>
I replaced the pads and not the rotor. I know, dumb move, but maybe since the rotor is fairly thin it does the same thing?
Old 05-11-2007, 06:11 AM
NirVTEC's Avatar
This is the BRAKE LAMP Gremlin......Just deal with it if youve already tried everything else.
My comes and goes and its been that way through several fluid swps, pad swaps, bulb swaps........It add to my Dashboard Christmas Tree!
SRS
ABS
BRAKE LAMP
BRAKE
I am convinced the MORE lights you have on, the faster your car is!
Old 05-11-2007, 11:40 AM
Yield's Avatar
Maybe, but I'm not sure I buy it. I had my fluid up to the high mark before I did the pad swap and it light didn't disappear immediately after the pad swap. It took a week
Nirvtec - I also think it might just be a bad connection/relay/gremlin somewhere. Back when I first bought the car it would come on sometimes when it was really hot out. Anyway, it's gone now...
Old 05-11-2007, 04:48 PM
TheWalrus's Avatar
Default Re: what dose the the"BRAKE LAMP" mean??? (Yield)
the float in your reservoir may have been stuck at the bottom...thats why those 2 wires are on the lid
BukThout
04-10-2007 07:44 PM
intech
11-17-2005 02:44 PM
FK00GSR
11-07-2003 12:32 PM
civicboisi
03-08-2003 06:45 AM
hybridbmw
02-19-2002 10:38 AM
Quick Reply: what dose the the"BRAKE LAMP" mean???
