vtec kick in?
Old 08-06-2004, 09:54 AM
ultraforce77's Avatar
Default vtec kick in?
just wondering when vtec should kick in on a jdm h22a w/ p13 ecu. mine dosen't kick in til 5,000 rpms. i thought it should be like 4,400. and i have a major power loss between 3,000 - 5,000 when i only have it at 50% throttle
Old 08-06-2004, 09:57 AM
AndyD's Avatar
Default Re: vtec kick in? (ultraforce77)
5000 sounds correct. 4400 is too low.
Old 08-06-2004, 10:14 AM
PreludeRacer023's Avatar
Default Re: vtec kick in? (AndyD)
5200
Old 08-06-2004, 10:49 AM
prelittlelude's Avatar
IAB solenoid activates on a P13 (91-96) at 4600, and 4900 on a P5M (97-01)
VTEC solenoid activates on a P13 (91-96) at 4900, and 5200 on a P5M (97-01)
Old 08-06-2004, 11:35 AM
Default Re: vtec kick in? (prelittlelude)
ok so it sounds like where its kicking in is about right... ok thanx guys
Old 08-06-2004, 04:27 PM
speedracer9k's Avatar
the cluster reads 5200, but its off 200, so actually about 5000 give or take
Old 08-06-2004, 05:31 PM
philjuba's Avatar
about your loss of power when @ 50% throttle is likely due to the TPS (Throttle Position Sensor). When you don't have the throttle opened past a certain point the vtec will not activate.
Old 08-07-2004, 08:59 AM
Default Re: vtec kick in? (philjuba)
ahhhhhhh i see would the O2 sensor have anything to do w/ it either? cause i think mine is bad, and i get crapy gass mileage
Quiks66
11-06-2003 09:00 AM
ATS_Antone
09-06-2002 08:43 PM
Quick Reply: vtec kick in?
