Transmission Stuck won't come off........ - Honda-Tech
Old 07-16-2009, 10:33 PM   #1
Default Transmission Stuck won't come off........
Hello everyone, Im hoping someone can help me determine the problem i am facing with my transmission. Im trying to take out my H23A1 transmission out to replace my clutch but after removing all the tranmission bolts somehow it stuck it won't come off (tranmission move side to side freely). I know that for Civic and Integra when you removed all the main bolt on the tranmision it should just fall right off. So with that being said my tranmission is still attach to my motor......Can it being that the clutch is still in gears? Before I took out the tranmission it was already in netural....Any help is really appreciate at this time.....
black94lude is offline   Reply With Quote
Old 07-16-2009, 10:55 PM   #2
matysik27's Avatar
Default Re: Transmission Stuck won't come off........
that wouldn't cause. just double check to make sure that they are all off you might have missed one bolt you can't easily see. Also make sure your pulling it straight off and not tilted at all.
matysik27 is offline   Reply With Quote
Old 07-17-2009, 12:33 AM   #3
Edul59's Avatar
the manual says to put the tranny and gears in reverse...i dont know if that will help you..also the shalft could be rusted in there too
Edul59 is offline   Reply With Quote
Old 07-17-2009, 01:09 AM   #4
Well the only thing I forgot or didn't do is to put into reverse gear. I didn't do that because I couldn't get a hold of a Haynes or Helms book. It seem like something has lock the shaft preventing it from pulling it out. I was just wondering if there is anything in the transmission can cause this problem.....?
Old 07-17-2009, 06:15 AM   #5
lude98SH's Avatar
The problem you are having has nothing to do with if its in gear or not. Make sure all the bolts are out and pull straight out. Also make sure its not getting hung up on anything. There really is not that much to it, don't overcomplicate things.
lude98SH is offline   Reply With Quote
Old 07-17-2009, 07:27 AM   #6
Okay thanks, I'll go back and double check to see if I have missed any bolts. So it doesn't really matter if the tranny is in gear or not it should still com out right? I go back and pull it straight out.....last night when I was trying to pull it out the tranny was kind of in a slant angle.
Old 07-17-2009, 08:52 AM   #7
Jago's Avatar
did you take the starter off?
Jago is offline   Reply With Quote
Old 07-17-2009, 09:30 AM   #8
roller3804's Avatar
There is snap rings on the end of each axel. You have to pop them loose. I bet the intermediate shaft is still in and making it hard to pop off. Use a prybar to pop it loose. Sometime its a PITA to get trannys off.
roller3804 is offline   Reply With Quote
Old 07-19-2009, 12:09 PM   #9
I finally got the transmission out. I pull it straight out and by prying the transmission from the motor. It took me a while before the transmission finally came off. From my inspection it appear like the shaft was super rust that why it was hard to get the transmission off. But thaks for all you guys advicse and support. I really appreciate it....
NEED EXPERT! mechanic broke tranmission bolt!! jesse777 Honda Accord (1990 - 2002) 12 06-18-2015 03:22 PM
Transmission mount Bolt question 95sloweg Honda Civic / Del Sol (1992 - 2000) 6 09-10-2010 10:31 AM
My car wont move yamahapunk154 Honda Civic / Del Sol (1992 - 2000) 21 04-17-2010 03:43 PM
TRANMISSION ryanj1025 Acura Integra 5 01-23-2008 09:04 PM
Clutch won't engage Nisif Tech / Misc 9 01-17-2008 12:55 AM
Tags
2000, 94, 98, bolts, civic, h22, honda, move, odyssey, prelude, pull, stuck, tramsmission, tranny, transmission, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
