Top Speed?
Old 08-05-2006, 08:12 PM
Unidentified's Avatar
Default Top Speed?
I have a quick and simple question:
I did the math and it seems to me that a stock H22A with a factory rev limit of 8200rpm and no top speed limiter bolted to an M2S4 should be capable of a top speed of about 173 mph on factory 4th gen. wheels and tires; correct? Can anyone confirm this?
Modified by Unidentified at 11:23 PM 8/5/2006
Old 08-05-2006, 08:34 PM
BDRphaSe2's Avatar
who the hell told you 8200rpm, that motor revs out at 7200, and ive topped mine in a controlled environment, at 155, with a m2s4 trans, and i duuno if it kep accelerating but it felt like it was stayin there..
Old 08-05-2006, 08:35 PM
InvaderTrax's Avatar
Mathematically, yes. However, it takes a lot of power to move 3000lbs to 173mph. More then the average H22 can make
Old 08-05-2006, 08:43 PM
blulude92's Avatar
Default Re: (InvaderTrax)
redline at 7200 rpm
fuel cut at ~7800 rpm
Old 08-06-2006, 01:58 AM
Buffalo's Avatar
Default Re: (blulude92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blulude92 &raquo;</TD></TR><TR><TD CLASS="quote">redline at 7200 rpm
fuel cut at ~7800 rpm</TD></TR></TABLE>
it seems to me that the redline starts at about 7400, not really sure tho but who knows, and yeah --&gt; fuel cut at 7800
Old 08-06-2006, 02:29 AM
pizzamanprelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDRphaSe2 &raquo;</TD></TR><TR><TD CLASS="quote">who the hell told you 8200rpm, that motor revs out at 7200, and ive topped mine in a controlled environment, at 155, with a m2s4 trans, and i duuno if it kep accelerating but it felt like it was stayin there..</TD></TR></TABLE>weight has nothing to do with his top speed, apart from drag created by the tires which increases with weight, horsepower and drag determine how fast you'll go, sorry but 200bhp is not going to take a prelude to 170mph, an rx7 with a lower coefficient of drag than a prelude with 286bhp can just make it past 170mph.
Old 08-06-2006, 08:23 AM
Silver Surfer's Avatar
the fastest i've been in my 4th gen is 132mph @6700rpms in 5th gear.......a curve was coming up so i had to slow down, but it was still pulling
Old 08-06-2006, 08:25 AM
paulwithap's Avatar
mine hits mach 1
SKDRCR's Avatar
Default Re: (Silver Surfer)
top speed 117, dam jdm p13
Old 08-06-2006, 04:05 PM
M2B4's Avatar
Default Re: (SKDRCR)
my top speed was 116 with f22. coulda got more but some dick cut me off on the interstate. but the day i test drove the car it went 120. i would like to hit the rev limiter on the f22.
Old 08-06-2006, 04:07 PM
Eddiebx's Avatar
Default Re: (M2B4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">my top speed was 116 with f22. coulda got more but some dick cut me off on the interstate. but the day i test drove the car it went 120. i would like to hit the rev limiter on the f22.</TD></TR></TABLE>
so soem guy cut you off going more than 116mph?
Old 08-06-2006, 04:15 PM
ECX
* B A N N E D *
ECX's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
so soem guy cut you off going more than 116mph?</TD></TR></TABLE>
eh, thats some sketchy ****.
thats why I hate driving the interstate sometimes
Old 08-06-2006, 06:40 PM
thomas188's Avatar
I hit 128 once in my f22 prelude pissed one night, but it has seen 125 maybe 2 other times and 120 others...try not to drive really fast often b/c of idiot drivers...although most would consider it idiot like to drive at these speeds i am talking about. Im from GA so i can hit some back roads that have 2 mile strait aways with no one on them.... Bout to be through boosted in 1.5 months and it will be interesting to see what the ol' prelude can do..
Old 08-06-2006, 07:55 PM
Default Re: (thomas188)
Ok, I build H23's and my H22 building buddy is the one that told me H22's rev to 8200 stock. However he failed to mention that his idea of a stock H22 is a JDM motor with a chipped P28/72. ie: no fuel cut, super high rev limit. I don't know if it's normal or not but I have personally seen more than one bone stock H22 rev to 8200 rpm both in neutral and through 4 gears with no problems at all.
On another note, my built H23 with no rev limit has taken me well over 140mph (controlled environment of course) on more than one occassion. Probably around the 150-155 mph range at about 7500rpm (Don't quote me on those numbers-speedo doesn't go as high as the tac). It still pulls extremely hard at this speed and was not showing any signs of slowing down. Someone has to have been higher than this with a more powerful higher revving engine? Who's gonna admit it?
Old 08-07-2006, 12:23 AM
Default Re: (Unidentified)
what horsepower did you push from your h23 build?
Old 08-07-2006, 05:19 AM
mgags7's Avatar
if one of you idiots tries topping out your 120whp f22 prelude on the freeway while im on there im launching nuclear missiles at your car
retards
Old 08-07-2006, 05:21 AM
Eddiebx's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">if one of you idiots tries topping out your 120whp f22 prelude on the freeway while im on there im launching nuclear missiles at your car
retards</TD></TR></TABLE>
you'd blow yourself up if your on the same hwy
retard.
BB4-Japanpower's Avatar
Default Re: (pizzamanprelude)
hi BB4 hits 180 KMH
thank god ive got no Speed limiter any more and my APEXI RSM shows 256 KMH on german highways
Old 08-07-2006, 05:35 AM
92nb's Avatar
Default Re: Top Speed? (Unidentified)
Needle all the way over for me...somewhere around 140
Old 08-07-2006, 05:57 AM
ECX
* B A N N E D *
ECX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unidentified &raquo;</TD></TR><TR><TD CLASS="quote">173 mph on factory 4th gen. wheels and tires
Modified by Unidentified at 11:23 PM 8/5/2006</TD></TR></TABLE>
another thing to take into account, not just rev limiter/fuel cutoff (if thats an issue, for some its not) is what the tires that came from the factory were rated to... just a thought
Old 08-07-2006, 06:51 AM
bluedlude's Avatar
Default Re: Top Speed? (ECX)
i cant say that i have ever hit the rev limiter, or fuel cut. ive brought it too the track, and for a 1/4 i have to hit 8000 for every shift or i have to shift into 4th, and ive never hit anything.
Old 08-07-2006, 06:24 PM
yOnKiNaToR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pizzamanprelude &raquo;</TD></TR><TR><TD CLASS="quote">weight has nothing to do with his top speed, apart from drag created by the tires which increases with weight, horsepower and drag determine how fast you'll go, sorry but 200bhp is not going to take a prelude to 170mph, an rx7 with a lower coefficient of drag than a prelude with 286bhp can just make it past 170mph. </TD></TR></TABLE>
you sure about horsepower and drag determining it? don't you mean torque, drag, and gearing?
horsepower is just a function of torque. gearing just multiplies it. correct me if i'm wrong.
Old 08-07-2006, 08:47 PM
DA is best's Avatar
fastest time i've gone was 145 mph on ice with the e-brake on, it dug a hole about 1/2 foot
Old 08-07-2006, 09:35 PM
moderator emeritus
98vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unidentified &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I build H23's and my H22 building buddy is the one that told me H22's rev to 8200 stock. However he failed to mention that his idea of a stock H22 is a JDM motor with a chipped P28/72. ie: no fuel cut, super high rev limit. I don't know if it's normal or not but I have personally seen more than one bone stock H22 rev to 8200 rpm both in neutral and through 4 gears with no problems at all.
On another note, my built H23 with no rev limit has taken me well over 140mph (controlled environment of course) on more than one occassion. Probably around the 150-155 mph range at about 7500rpm (Don't quote me on those numbers-speedo doesn't go as high as the tac). It still pulls extremely hard at this speed and was not showing any signs of slowing down. Someone has to have been higher than this with a more powerful higher revving engine? Who's gonna admit it?</TD></TR></TABLE>
why rev that high on a stock motor tho? jdm motor with nice bolt ons and tuning stop making power around 7400.
Old 08-08-2006, 12:40 AM
Default Re: (yOnKiNaToR)
yes am pretty sure, there's equations for everything but basically if you want to go stupid fast you need horsepower, not torque, and a low co-efficient of drag. my audi a4 diesel has twice the torque of my prelude and my prelude can kick its ***. brake horsepower is a measurement of torque over one minute so you could argue that you need high end torque for top speed, depends how you want to look at it
Quick Reply: Top Speed?
