Symptoms of a seized caliper? - Honda-Tech
Old 04-11-2006, 10:56 AM   #1
es_squared's Avatar
Default Symptoms of a seized caliper?
I remember having this issue with the front driver side.. i would see lines around the caliper, and it turned out being a siezed caliper when i took it in. Same thing with the rear now, lines around the brake caliper. Could i just check by taking the pad out and seeing if the piston goes in/out properly?
es_squared is offline   Reply With Quote
Old 04-11-2006, 11:59 AM   #2
britishlude's Avatar
Default Re: Symptoms of a seized caliper? (es_squared)
Do you mean lines around the rotor ? The way to check if calipers are sticking is to jack up the rear of the car on level ground, chock the front wheels and car in gear for safety firstly, release the handbrake and turn the rear wheels by hand. They should turn reasonably freely if caliper is not seized, if they are difficult to turn then your calipers are sticking.
Modified by britishlude at 8:09 PM 4/11/2006
Modified by britishlude at 8:15 PM 4/11/2006
britishlude is offline   Reply With Quote
Old 04-11-2006, 01:13 PM   #3
ShinobiLude's Avatar
Default Re: Symptoms of a seized caliper? (britishlude)
Dont run it too long with a seized caliper or you will FUG your master cylinder all up.
ShinobiLude is offline   Reply With Quote
Old 04-11-2006, 01:54 PM   #4
Hondaen's Avatar
Easy, after a ride, just feel the temperature on each rim.
If one rim is hoter than the rest, you have a brake problem.. worn pads of sticking calipper.
Hondaen is offline   Reply With Quote
Old 04-11-2006, 06:12 PM   #5
es_squared's Avatar
Default Re: Symptoms of a seized caliper? (Hondaen)
thanks guys, ill check it over
Old 09-25-2006, 06:57 PM   #6
da_33's Avatar
u can also smell something different after getting out of your car if one is seized
da_33 is offline   Reply With Quote
bleeding caliper with broken bleeder SQ is the SQUAD Tech / Misc 9 12-22-2011 09:35 PM
Upgrading Calipers on 00 Coupe JPerkMr954 Honda Civic / Del Sol (1992 - 2000) 5 12-15-2010 01:45 PM
FS: Spoon Monoblock Calipers cccoltsicehockey For Sale 32 04-26-2010 09:45 AM
Caliper Bolts will not tighten?! dL_EG6 Acura RSX DC5 & Honda Civic EP3 3 12-09-2008 12:18 PM
Help with front caliper piston! harryg Tech / Misc 3 02-13-2003 06:05 AM
Tags
acura, brake, caliper, calipers, checking, civic, honda, identify, rear, rsx, seized, seizing, siezed, symptom, symptoms, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
