squeeking noise
squeeking noise
When i have my wheel turned to the right while driving. Their is a high pitched squeeking noise. Also there is a lot of "play" on the steering wheel when i hit bumps and potholes. Does this have anything to do with the power steering fluid?
Re: squeeking noise (imported204)
First, check your power steering fluid. Then check the tightness of your power steering belt, it sounds like your belt is a little too loose. There are 3 bolts that hold your p/s pump on, loosen them then to tighten the actual belt there is a bolt on top of the p/s pump and you want to tighten that, thus creating more tension in the belt. As far as the play on the steering wheel, i really dont knwo what to say.
New User
The squeaking seems like a loose belt to me too... but the "play" in the wheel doesn't follow with that or with low ps fluid.... If it were more of a "clicking" sound the first thing I would think in CV joints. Answer Chiovnidca's questions and things like what kind of modifications you have and mileage on the car and someone will have a better chance of giving you a good answer...
EG2Driver
06-08-2006 06:21 PM
