Speedometer Problem....bad VSS?
My speedometer has been acting up recently. Sometime while driving the speedometer will fall to zero and stay there. However, at other time it would pop back up to speed, but drop again a few moment later. At other time the speedo would totally not work at all when I start driving. If the speedo continue to not work for a few minutes the check engine light would come on.
So is this a Vehicle Speed Sensor VSS problem or can it be something else? If this is a VSS problme, where is the VSS located on a 92 2.3L MT Si?
Thank you!
Thank you!
Location: Free bullets if you find me sucka, Washington
1 Post
Re: Speedometer Problem....bad VSS? (f155mph)
yes it is a VSS problem..................top of the tranny....look for diagrams but you can feel it, of you know what your looking for........
try cleaning it first...brake cleaner and a wire brush....
be very careful while bolting it down(putting it back).. i have heard stories of people putting too much pressure in the bolts breaking whatever the sensor sits on.....
most hood white kid
Re: Speedometer Problem....bad VSS? (I got the CD5 Jeebies!)
look directy under your shifter cables for a plug(where the shifter cables hook up to the tranny). to replace it, I would remove the cables, I had too, plus its easier. its not hard tho, and I got mine for 50 bucks...
Re: Speedometer Problem....bad VSS? (egcoupe94)
if it was you vss you would get a cel because the ecu would not see a speed input
sounds more like a speedo head
1 Post
Re: Speedometer Problem....bad VSS? (Jago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago »</TD></TR><TR><TD CLASS="quote">if it was you vss you would get a cel because the ecu would not see a speed input
sounds more like a speedo head</TD></TR></TABLE>
not nesasarily there is always that 10%
most hood white kid
he is throwing a CEL every now and then. I am 99% sure its the VSS
most hood white kid
Re: (f155mph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f155mph »</TD></TR><TR><TD CLASS="quote">I was looking around for it yesterday. Does the VSS sit right under the some cables under the TB intake?</TD></TR></TABLE>
those would be your shifter cables...it is MUCH easier to remove if you just unclip the cables from their mounts...
I notice a pattern. So it seem that the problem relate to temperature. When the temp is really hot outside or the engine is fully warmed up I don't have a problem. However the last two days been a little cooler and the speedo would not work until the car get fully warmed up. Today was hot and the speedo worked fine again. What might be wrong with the vss that make temperature a factor?
PGHRich
11
09-10-2010 05:18 PM
