speedometer not working
i got a 92 lude si 5 speed. and my speedo isnt working after i replaced the clutch. i think the sensor is connected but im not totaly sure... where is it located?
Re: speedometer not working (1992hludesi)
yeah the sensor may be plugged in , but is the whole vss put back in the tranny and bolted down?
one of the steps is to remove the vss and set it aside, you either forgot to plug the vss conector in or, forgot to insert the vss back into the tranny
Re: speedometer not working (prelittlelude)
does there have to be power steering fluid and the hoses runing in and out for the speedo to work? also. would that cause a check engine light.
i currently do not have the power steering hoses connected. and i have no power steering fluid
the vss will cause a check engine light eventually, and no there doesn't need to be powersteering fluid for the vss to work. anyone that eliminates powerstearing just loops those lines at the vss.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992hludesi »</TD></TR><TR><TD CLASS="quote">i got a 92 lude si 5 speed. and my speedo isnt working after i replaced the clutch. i think the sensor is connected but im not totaly sure... where is it located?</TD></TR></TABLE>
The VSS is on the far right in this pic with the 3 brass-colored screws close to eachother...
Check the actual sensor and check the electrical connector.
Yep - man, I did the same exact thing when I replaced my clutch. Haven't had time to look at it - the prelude is parked. Most likely, the sensor is plugged in - but its not in properly. This is my case.
The check engine light will come on when you're engine breaking - maybe at like 4,000 or so. Power steering won't effect it whatsoever. Find some time to check it out - little people might not need a lift -but i'm pretty big
