spark plugs configuration
Re: spark plugs configuration (ncsuprelude)
this is gonna be kinda hard to explain. the cylender farthest from the distributor, closest to timing belt is 1, and they go in order. on the distributor, the top spot towards the front of car is 1, top spot in the rear is 2, bottom spot in front is 3 and bottom spot in rear is 4. making the firing order 1,2,4,3. im sure theres an easier way to explain it, but im stupid.
Re: spark plugs configuration (Flood5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flood5 »</TD></TR><TR><TD CLASS="quote">This should answer it.
so that would be for an h22a1 right?
Thats the correct diagram for the H and B series Honda engines.
Try it, if its wrong, it will run like ****, change them around and figure out where they go. It's like a puzzle.
Re: (bb4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">
There is a dot on the distributor cap next to the #1 terminal, after that go 1-3-4-2 clockwise</TD></TR></TABLE>
does this apply for the autozone distributor caps?
i have a better idea, why doesnt a knowledgeablt and nice H-T member take an actual pic of their spark plug wires set-up on their motor, so we could get a better reference?
Modified by dek1mfk at 10:18 PM 11/13/2006
Re: (bb4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">yea if you look straight at that picture, the #1 is bottom, then #3 is to the left, mid height, the #4 is on the top, then the #2 is on the right</TD></TR></TABLE>
so the white circled one is wire #4 and the red one is #2?
Re: (dek1mfk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dek1mfk »</TD></TR><TR><TD CLASS="quote">
so the white circled one is wire #4 and the red one is #2?</TD></TR></TABLE>
yes, correct blue is 1, yellow is 3, white 4, red 2
I ziptied them on because msd wires like to pop off and fry my ignition coils...
GsrTurboCRX88
13
03-23-2006 05:31 PM
irdprelude
02-19-2005 12:51 PM
