spark plug tubes with oil - Honda-Tech
Old 01-13-2017, 12:58 AM   #1
94vtirozguy's Avatar
Icon6 spark plug tubes with oil
was driving through the country having a nice drive and all of a sudden turning into a street, dropped the clutch and engine stalled, when it started again I got it stalling every time I put clutch in.
Seemed a little odd to happen all of a sudden and the car started chewing through fuel, idling like it was untuned weed whacker. Got her home and found 2 spark plugs covered in oil, and two were black (happy as I thought timing belt may have slipped - not good in built engine).
So I have seen the kits that replace the valve cover gasket, the bolt gaskets and the upper spark plug seals which is all good. What I want to know and is not clear in the service manual is, do the h22a1's have o-rings
for lower seals for the spark plug tubes like in other Hondas that you have to pull off the top of valves to get to. If so what are the part numbers / correct kits for them ?
94vtirozguy is offline   Reply With Quote
Old 01-13-2017, 07:22 AM   #2
Moderator
snobordboy's Avatar
Default Re: spark plug tubes with oil
Nope, just the upper spark plug seals that you get to when you pull the valve cover.
snobordboy is offline   Reply With Quote
Old 01-13-2017, 04:38 PM   #3
thanks.
Old 01-13-2017, 09:40 PM   #4
TheJGB3's Avatar
Here you go.
https://www.hondapartsnow.com/parts-...over-vtec.html
#1 is the complete kit and includes #3 the gasket, #4 the sparkplug tube seals (qty4), #12 the grommet (qty8)
If the sparkplug tips themselves have oil on them then you have leaking valve guide seals in the cylinder head which is a completely separate issue.
https://www.hondapartsnow.com/parts-...nder-head.html
#4 is the intake valve seal #5 is the exhaust seal
TheJGB3 is offline   Reply With Quote
Old 03-12-2017, 12:12 AM   #5
ok I replaced the spark plugs and the seals all is good.
However the car is still running rough and smells of fuel. I suspect error code 10, so I pulled off IAT plug and plugged in a new IAT to atmosphere and still runs and idles like crap.
any ideas
Old 03-12-2017, 01:18 AM   #6
did you use oem sensor?
TimiK is offline   Reply With Quote
Old 03-12-2017, 03:18 AM   #7
Check for voltage at the connector. Should be either 5v or battery voltage. If not, you got an issue with the connector or the wiring back to the ecu.
holmesnmanny is online now   Reply With Quote
Old 03-13-2017, 04:49 PM   #8
motoxxxman's Avatar
Quote:
never suspect anything. either you have a code 10 or you do not have a code 10. which is it? and what other codes do you have?
motoxxxman is offline   Reply With Quote
Eating oil/stalling DuniCraig All Motor / Naturally Aspirated 4 12-11-2015 02:02 PM
misfire or not? acidburn2k2 Honda Accord (1990 - 2002) 4 08-31-2015 05:43 PM
any of you turbo ls have this oil problem? the.hamburglar Forced Induction 18 05-22-2006 10:18 PM
Valve Tap/ Valve Cover gasket Replacment f22... standbackimapro Honda Accord (1990 - 2002) 5 04-29-2006 05:38 PM
RPM's dropped to zero and car won't start (long) Adam_F123 Honda Accord (1990 - 2002) 8 09-12-2004 06:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
