Spark pllug wires: what you guys think.
My 1998 Prelude has 162k miles on it. I highly assume that it is still using stock OEM spark plug wires. Do you guys recommend me buying a new set of NGK wires while I replace my spark plugs?
Thanks.
Thanks.
Re: Spark pllug wires: what you guys think. (ZXRider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZXRider »</TD></TR><TR><TD CLASS="quote">My 1998 Prelude has 162k miles on it. I highly assume that it is still using stock OEM spark plug wires. Do you guys recommend me buying a new set of NGK wires while I replace my spark plugs?
Thanks.</TD></TR></TABLE>
Good question. I think it's about time mine should be changed. They are looking cracked and discolored - they are Honda wires. Do aftermarket "big" wires make a difference with a 'lude? I have an H22A1.
moderator emeritus
Re: Spark pllug wires: what you guys think. (M2B4)
your way over due to change them if they havent been changed in 162k miles
NGK also gets my vote since i use them.
moderator emeritus
Re: Spark pllug wires: what you guys think. (HondaTheory)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTheory »</TD></TR><TR><TD CLASS="quote">Good question. I think it's about time mine should be changed. They are looking cracked and discolored - they are Honda wires. Do aftermarket "big" wires make a difference with a 'lude? I have an H22A1.</TD></TR></TABLE>
no, the factory ignition can actually support a good amount of hp and really only needs to be replaced as maintainance or when you want to "bling" your engine bay.
after running that many miles on those plug wires, your engine will likely run smoother.
Re: Spark pllug wires: what you guys think. (Hawkze_2.3)
^the only thing i didn't like about my magnecors is they didn't cover the sparkplug hole correctly (i'm guessing this is what you mean by fitment)
1 Post
Re: Spark pllug wires: what you guys think. (petern101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 »</TD></TR><TR><TD CLASS="quote">^the only thing i didn't like about my magnecors is they didn't cover the sparkplug hole correctly (i'm guessing this is what you mean by fitment)</TD></TR></TABLE>
Yep, they just 'sat' on top of the spark plug hole...didn't snap on or anything.
Re: Spark pllug wires: what you guys think. (cb7-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R »</TD></TR><TR><TD CLASS="quote">MSD </TD></TR></TABLE>
dotmichael to you
Re: Spark pllug wires: what you guys think. (mgags7)
hear waaaaaaaaaaay too many horror stories about MSD.
I'm actually looking to buy new plug wires tomorrow for my 97 base...I dont need anything larger than stock MM...but i'm just curious as if I should just pick up plugs from advance auto/pep boys/ autozone or get one from majestichonda (OEM)
I probably wont keep the car longer than a year...but I dont want to get something shitty for it.
Re: Spark pllug wires: what you guys think. (. M i c h a e l)
Instead of the PZFR6F-11 Platinum plugs get the ZFR6F-11 copper NGK plugs. They won't last as long as the platinum plugs but they will do everything else. Only reason Honda used the platinum tipped ones in the Prelude was because they wanted the spark plugs to lask 100K+ The platinum ones are like $20 from a dealer and the cheapst i found online was $11.
Re: Spark pllug wires: what you guys think. (vinuneuro)
should of posted my toping here but didnt see it, its almost similar question
https://honda-tech.com/zerothread/1748506
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZXRider »</TD></TR><TR><TD CLASS="quote">Instead of the PZFR6F-11 Platinum plugs get the ZFR6F-11 copper NGK plugs. They won't last as long as the platinum plugs but they will do everything else. Only reason Honda used the platinum tipped ones in the Prelude was because they wanted the spark plugs to lask 100K+ The platinum ones are like $20 from a dealer and the cheapst i found online was $11.</TD></TR></TABLE>
honestly even autolite plugs will do, just tune your car for them, jd3jdm's 250+whp h22 runs autolite plugs, a set is like $8....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">
enlighten me with your wisdom young one...why
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l »</TD></TR><TR><TD CLASS="quote">hear waaaaaaaaaaay too many horror stories about MSD.
What kind of horror stories can a plug wire cause???? Any links???
dotmichael to you
enlighten me with your wisdom young one...why </TD></TR></TABLE>
What kind of horror stories can a plug wire cause???? Any links???</TD></TR></TABLE>
Look bud, just because you've had a good experience with them means nothing. Most people I've encountered that use MSD have problems.
Trust me, you are definitely in the minority.
Are the wires Sumitumo?
Ok so what are the problems?? I would simply like to know. I have never heard anyone complain about them. If your info is hearsy then bite me...
dotmichael to you
Are you a rep for MSD or something? You're getting real defensive (read: being an *******) about it.
Do your own search.
Do your own search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R »</TD></TR><TR><TD CLASS="quote">enlighten me with your wisdom young one...why </TD></TR></TABLE>
Frying ingition coils like its my job....
**** on any spark plug wire that wont stay one the dizzy......
young one.....lol you must thing youre the ****, dont you?? thats nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R »</TD></TR><TR><TD CLASS="quote">Ok so what are the problems?? I would simply like to know. I have never heard anyone complain about them. If your info is hearsy then bite me...</TD></TR></TABLE>
didn't someone just post problems with their MSD wires always popping off and causing the distributor to run hard which is blowing out his coil.
and then ppl are responding by saying the wires are popping off.
