should i do my own suspension?
Old 04-16-2008, 07:41 AM
pkolaboy's Avatar
Default should i do my own suspension?
i know its really risky but has anybody done thier own suspension? would you recomend me?...
Old 04-16-2008, 07:45 AM
BergRacing21's Avatar
Default Re: should i do my own suspension? (pkolaboy)
do you do most of your own work? if so suspension is not hard at all as long as you have the right tools. it's a couple of bolts and a matter of compressing the springs or...if you're doing full coilovers just take the strut out spring and all and put your new ones in...suspension is actually quite easy.
Old 04-16-2008, 07:47 AM
subydoored's Avatar
Default Re: should i do my own suspension? (BergRacing21)
so easy to install suspension you can rent a spring compression too from just about all auto parts places
Old 04-16-2008, 08:06 AM
pkolaboy's Avatar
Default Re: should i do my own suspension? (subydoored)
yea but what if you make the wrong move or something, wont the spring fly out...because i know if that does happen then im screwed...
Old 04-16-2008, 08:11 AM
like subydoored said it is very easy to do suspension, im sure there are threads explaining how to do suspension so i won't explain it. but the chances of you having the spring fly out or the shock dropping are rare as long as you do it step by step and know what you're doing. as long as you use spring compressors it's not hard. that's all im saying.
Old 04-16-2008, 08:24 AM
Simple_Sauce's Avatar
I dont even use a spring compressor. I just let it fly off. If its your first time, it will probably take you a whole day to figure it out.
Old 04-16-2008, 08:28 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkolaboy &raquo;</TD></TR><TR><TD CLASS="quote">yea but what if you make the wrong move or something, wont the spring fly out...because i know if that does happen then im screwed...</TD></TR></TABLE>
Just get a Helms manual and read the suspension section first and you should be fine. Also get some spring compressors for sure.
DO NOT just go into to it blindly without having any idea what you're doing, that could get you hurt.
Old 04-16-2008, 08:49 AM
subydoored's Avatar
Default Re: should i do my own suspension? (Hawkze_2.3)
i let the spring fly also i just aim it away from breakable stuff and yourself. per side you have the 4 or 5 lug nuts and 7 bolts you take off. 5 are in the engine bay 3 are the shock itself the other 2 is the upper control arm. then 1 of the bolt is the fork bolt attached to the lower control are and the other bolt is the bolt holds the shock to the shock fork. hardest part is taking the shock out.
DC5mike
12-11-2008 01:05 PM
Dr. Willy
Suspension & Brakes
10-09-2007 10:32 PM
Jason C SBB
08-05-2003 06:48 PM
itr1236
03-06-2003 09:13 PM
Matt Groove
10-15-2002 07:16 AM
Quick Reply: should i do my own suspension?
