Help! Stuck with no ride! No start
Old 05-05-2012, 07:20 PM
T-Mo's Avatar
Default Help! Stuck with no ride! No start
Ok I had a misfire so I changed the plugs, wires, cap, and rotor button. I set the firing order wrong but then I googled and set it right and it fired up and ran fine. I took it up the road, and came back. It still had a slight misfire so I pulled each plug wire starting with cylinder one. It chgd in each one until I got to cylinder 4. When I took that one off the car died and now it won't start anymore. It turns over but won't crank up.
Did I mess something up? Where should I start? 1996 Prelude Si h23
Old 05-06-2012, 09:24 AM
T-Mo's Avatar
Default Re: Help! Stuck with no ride! No start
Wow 169 views but no responses?
Old 05-06-2012, 10:23 AM
godslayer's Avatar
After running the car with an incorrect firing order you then start randomly pulling wires all while the car is still running? Pull the plugs and take a good sniff. $20 says your plugs are just soaking in gasoline and now they'll either need to be dried or replaced.
Old 05-06-2012, 11:14 AM
P. Hunter's Avatar
this is what i would do first..
gotta check the obvious/easiest things first...
Old 05-06-2012, 04:02 PM
T-Mo's Avatar
I didn't run the car with the wrong firing order. I tried to start it and got nothing. I then set it correctly. I drove it around with the CORRECT firing order but it was still misfiring. That is when I pulled the wires one by one trying to see if one of the cylinders was possibly dead. When I pulled the 4th cylinder wire out, it stalled and before I could push the wire back down, it died and hasn't started back up since then.
I pulled the plugs and the were NOT soak. I pulled the valve cover, timing was dead on. I checked to see if the rotor button jumped off. It was still there. I changed the coil and main relay and got nothing. Fuel pump is priming so idk.
So now I am hoping that it's just the distibutor. That's my last guess. I will probably rent a compression tester from work and make sure that compression is good across the board. Then purchase a new distibutor.
Question: Are there any other make and models that I can get a distributor from if I was to go to the junkyard. 1996 Prelude Si H23
Old 05-07-2012, 12:36 AM
prelude2.2's Avatar
The same **** happened. To me exacly how urs turned off mine did too and it was my internal coil I have a jdm h22a with a internal coil replaced it and fired back up check to see if ur fuel pump turns on and if ur igniter didn't take a **** just grab a test light youtube a video I watched one for a civic
teamTakeo
08-20-2023 07:58 PM
guido45
02-01-2008 06:47 PM
marcusgnf
03-09-2005 07:12 PM
AlexT
10-13-2004 05:45 PM
Quick Reply: Help! Stuck with no ride! No start
