Is 50000 miles ok to still put supercharger
Old 01-11-2005, 10:45 AM
kriptik's Avatar
Default Is 50000 miles ok to still put supercharger
ok guys my car is obiously broken in very much with that kind of mileage, it is in very very good condition no problems with it, now with that high of mileage can i still put a super charger and maintain dependability of my car or wut do i risk, thanx prelude community
Old 01-11-2005, 11:07 AM
puffxy's Avatar
I'll assume it's a 5th gen?
It 50k shouldn't be a problem for an sc, just run a compression test, and if you're really picky, a leakdown test. If everything checks out, you're good to go. Good luck.
Old 01-11-2005, 11:38 AM
bleacht's Avatar
Default Re: Is 50000 miles ok to still put supercharger (kriptik)
50K is nothing, just listen to puffxy's advice.
Old 01-11-2005, 12:57 PM
5200BB6's Avatar
Default Re: (puffxy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by puffxy &raquo;</TD></TR><TR><TD CLASS="quote">I'll assume it's a 5th gen?
just run a compression test, a leakdown test. If everything checks out, you're good to go. Good luck. </TD></TR></TABLE>
Old 01-11-2005, 01:04 PM
homesauce's Avatar
Default Re: (5200BB6)
reliable tho? hahaha, from my experience forced induction h22's are far from "reliable", reliable as in not putting much money to maintain parts/repair parts.
Old 01-11-2005, 01:08 PM
revlimitx04's Avatar
You could supercharge a prelude with 150k miles as long as a compression and leakdown test yield good results... boosting isnt near as reliable as the stock setup, but its safe, defentily on 50k. Makes sure you have it dyno-tuned correctly and you should be fine.
Old 01-11-2005, 03:12 PM
H22A4 Prelude's Avatar
Default Re: (revlimitx04)
50K? thats absolutely nothing for a Honda. seriously, we got engines that dont really even "break-in" till about 60k. compression test then boost the **** outa it. go for it man.
Old 01-11-2005, 03:22 PM
MeUglyDuckie's Avatar
my car just hit 50000 miles LOL planin to sc it too, but too broke to do it though and would it be good with stock internals?
Old 01-11-2005, 03:25 PM
LudeBehavi0r's Avatar
dude, i just bought a 4th gen with 50k on it, feels like a brand new car. As long as ur compression and leakdown tests yield good results, ur good to go.
Old 01-11-2005, 03:31 PM
satan_srv's Avatar
Default Re: (Ludebehavior85)
don't forget to save for your motor rebuild! you'll need it!
Old 01-11-2005, 05:03 PM
lenn's Avatar
Default Re: (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">don't forget to save for your motor rebuild! you'll need it!</TD></TR></TABLE>
^^ what he said, it'll happen eventually. There are the same inherent risks of boosting a 50k mi motor as there are boosting a 10k mile motor. Just make sure you have plenty of "rainy day money" lying around. FI is reliable after the first year where all the kinks and problems show up, then its regular maintainence from then on out.
A FI car will never be as reliable as a stock car (duh). BTW, go with a turbo instead... you'll spend about the same and your lude will have much more potential (in regards to being able to fit intercooler, run higher boost, fit a variety of different turbos to the setup). But this thread isnt about to SC or to turbo.
Anyways, i think i've said enough, 50k is fine as long as the compression and leakdown numbers are good. make sure you perform a compression and leak down, dont skip the step....
Old 01-11-2005, 05:05 PM
satan_srv's Avatar
Default Re: (lenn)
You need excellent standalone engine management and great tuning to make any sort of Forced Induction last on stock H22a internals.
It's sad when I think about how many people I've personally had this discussion with, only for them to ignore me, spend all this money, blow their motor, and look like an idiot. And a poor one riding the bus at that.
Old 01-11-2005, 06:55 PM
Paluce's Avatar
It's all about the engine managment. I run an 11.5:1 A/F ratio on the high cam, and still put down 227hp on a mustang dyno @6psi. Most people run 12 or 12.5:1 ratio, but I've never seen them gain any power in doing so, so why do it? I'm 100% against running an SC car without an intercooler that lean. I've put 87,000km (60,000mi) on my SC. no problems YET. I autocross, drag and go to the track... run the car rich and with a good amount of timing retard, and you'll be fine.
acuracy r
02-27-2005 08:54 AM
AzntaggeR
10
10-18-2004 07:25 PM
tweekerz
04-30-2004 09:43 AM
projektCRX
04-22-2004 12:18 PM
oMek
10-27-2003 12:04 PM
Quick Reply: Is 50000 miles ok to still put supercharger
