replacing msd blaster coil 2 with stock external coil?
I was wondering if i can just replace the stock external coil with the msd blaster coil be putting the 2 wires on it. I wanted to try it to see if my stock coil is bad. but the ? is that will the msd coil plug right on??
oh yeah, on the stock coil, theres a yellow, and a yellow/blk wire, u connect those two together, or it wont work. just connect those two together, then run it to the + side of the coil, and your set
Re: (Eddiebx)
So connect yellow and yellow/blk wire together can put on the + coil and then negetive green on coil? I can still run it with stock spark wires right? thanks man i gotta try this out and see if the stock coil is out.
Re: (Eddiebx)
You can test the stock coil to see if it's bad.
IMO, you're wasting your money on that coil.
Good luck though.
BTW, I wouldn't hack your stock connector if I was you.
Make sure you solder your connections if you decide
to use that msd coil.
Good luck though.
951dc5
06-09-2005 06:51 PM
