Removing stock headunit
Have to remove my stock headunit to pull the serial number (damn anti-theft crap). As far as I know you just take a flathead and pop off the panel surrounding the radio, right? Then there's 4 12mm bolts to unscrew...
Any tips for doing this? I have the factory wood trim and don't wanna ruin it.
Thanks.
Thanks.
You have wood grain in your whip? Damn....is that a 5th gen? Didn't know they had those....:thumbsup: though.....
my thoughts - just be patient while doing it.
Re: (NaptownKing)
just look at everything..get down there and see how it is put together...your gonna have to use some force gettin it off...but make sure your pullin where your supposed to be , not on somethign you will mess up....its not complicated
Re: (Jordan25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordan25 »</TD></TR><TR><TD CLASS="quote">just look at everything..get down there and see how it is put together...your gonna have to use some force gettin it off...but make sure your pullin where your supposed to be , not on somethign you will mess up....its not complicated</TD></TR></TABLE>
Have you ever taken a 5th gen apart? I'm looking at the schematic and there doesn't seem to be a lot to "pull" on.
OT: My gf grew up in Marion, IA.
Re: (Tomakit)
ok i have pulled my 5th gen apart and it isnt that hard. all you do is start at the gbottom with your bare hands and pull a little untill it pops down there, then work your way up and pop the side ones and then the top and its off. its a little tedious but simple. dont use the screwdriver
reid
reid
Re: (Jordan25)
Their are 8 clips that hold the center trim panel on. 3 on top, 2 on sides and 3 on the bottom. It takes quite a bit of force to get it off.
Once you have that off 4 screws hold the audio unit in place. Thake those off and the radio will cpme out easily.
