radiator problems.... major problem
hi yea.... we got my car running last night and it is running fine except that the radiator fans are not turning on to cool the engine and the engine temp went up pretty high. when we shut the key off the left fan on the radiator came on. then we tried to jump the fan to make it cool the engine (while the engine was running) at the coolant neck on the front of the block.... it didn't work... so then we tried to at the thermostat and that didnt get it working while the car was on. so then we just jumped the right radiator fan straight from the radiator connector to the battery and a ground to cool the engine. and when we did that the left fan wouldn't come on anymore when we turned the key off. the other thing we noticed was that none of the climat controll unit was working the heat, the blower fan, and the a/c. we checked the fuses and couldnt find any that were bad.
does anyone have any ideas whats going on?
my car is a 92 prelude si with a swapped h22... and we are using the factory h23 harness on it.
thanks
thanks
Notpretty
01-31-2008 10:24 PM
