Question about wheels?
Will 1990 Nissan 240 wheels fit on a prelude i found some technical specs. The reason I ask is because i'm looking into buying some wheels for my prelude, but the wheels are from a 240.
MODEL: PRELUDE SI
Year: 92-96
Size: 15 X 6
P.C.D. 4X114.3
Lug Size: 12mmX1.5
MM: 64.1
Offset: H
MODEL: 240SX
Year: 89-96
Size: 15 X 6
P.C.D. 4X114.3
Lug Size: 12mmX1.25
MM: 66.1
Offset: H
Offset H = High Positive or FWD (Front Wheel Drive) typically +45,40,35 offsets
Thanks in advance,
Jacen
MODEL: PRELUDE SI
Year: 92-96
Size: 15 X 6
P.C.D. 4X114.3
Lug Size: 12mmX1.5
MM: 64.1
Offset: H
MODEL: 240SX
Year: 89-96
Size: 15 X 6
P.C.D. 4X114.3
Lug Size: 12mmX1.25
MM: 66.1
Offset: H
Thanks in advance,
Jacen
1 Post
tires are too tall, and you'll want to find the exact offset for the wheel before you go ahead and buy some. the difference b/w +30 and +45 is huge in terms of looks and compatibility.
Re: (CFran55)
If I remember a 4th gen Prelude's offset is +50....but I could (and prolly am) wrong
Anyways, I'm kind of in the same field, I want some wheels that I assume are intended for Nissans with a +35 offset for my Prelude, before I spend the money I'd like to make sure they fit (16x7 btw)
Re: Question about wheels? (Jacen)
45et sounds right to me about that offset for the 92-96 prelude. Pretty sure that the 240 wheels are going to be to low of n offset for the lude. Usually the rear wheek drive applications dont fit the fwd applications.
