Prelude overheat issue
Old 01-22-2014, 04:27 AM
Grape Ape Guy's Avatar
Default Prelude overheat issue
Buddy of mine asked me to get his car to dd status,
01 prelude
h22 motor 200k
5 speed
maintenance unknown
The car has no heat (plugged heater core? cooling system fix a leak crap?)
the car will sit and idle all day but lopes (iacv? )
will only drive 5 miles before overheating
I am assuming heater core is plugged, so may be the radiator,
Going to start by flushing the radiator/cooling system, replace thermostat and then?
anyone have similar issues that would care to toss in their $.02
Old 01-22-2014, 02:43 PM
AvengerZim's Avatar
Default Re: Prelude overheat issue
Sounds like blockage of some sort, i had a similar issue, was a kinked hose from when i was doing other work.
Old 01-23-2014, 08:15 PM
holmesnmanny's Avatar
The heater system bypasses the cooling system. It won't cause the system to overheat at all.
Idle the car and check to be sure the lower hose starts getting hot before the car overheats. If it stays cold your issue is the thermostat is bad and is sticking closed. The reason for this is that it's not a Honda OEM thermostat which will simply open and stay open when it goes bad which will not cause your car to overheat, it will just run colder.
If the lower hose does get hot make sure the fans come on. If not, then your issue lies in that system. Report back.
Old 01-24-2014, 05:37 AM
z71rider's Avatar
water pump maybe?
JoshMerchant
03-13-2015 10:27 PM
xolk88
10
03-18-2010 05:18 AM
oompalumpa61
01-08-2009 03:24 PM
BLK_TEG_007
11
03-28-2008 09:41 AM
Cashis Lee
04-28-2005 04:29 PM
Quick Reply: Prelude overheat issue
