prelude ignition help!!! - Honda-Tech
Old 10-14-2007, 11:15 AM   #1
dapaur's Avatar
Default prelude ignition help!!!
i just put a h23 motor in my boys prelude. The motors completly in i prime the head and put the fuse back in for the fuel pump and go to start it. it just cranks so i check fuel has fuel check spark there no spark. there no spark coming from the coil to distrubutor. i put coil from old motor on the car. there is power going to coil and i changed out the main relay still nothing checked all the fuses etc. the coil and dist. came off the orignal motor in the car before we pulled it. it had spark the coil and dist worked fine but now nothing. can anyone tell me where to go from here im lost thanks
dapaur is offline   Reply With Quote
Old 10-14-2007, 07:12 PM   #2
dapaur's Avatar
Default Re: prelude ignition help!!! (dapaur)
bump
Old 10-15-2007, 10:15 AM   #3
Hawkze_2.3's Avatar
Hard to tell what you're saying with that jumble of words, but have you checked the ECU ground on the thermostat housing? That will keep it from starting...
Hawkze_2.3 is offline   Reply With Quote
Old 10-15-2007, 02:08 PM   #4
dapaur's Avatar
Default Re: prelude ignition help!!! (Hawkze_2.3)
no havent checked the grounds assumed grounds where good if the coil has power
and simplified version i have power to coil coil works but i have no spark going from coil to distrubtor
Old 10-15-2007, 06:33 PM   #5
dapaur's Avatar
bumppp
Old 10-15-2007, 10:07 PM   #6
Hawkze_2.3's Avatar
OK, so how do you know you have power to the coil? If the coil is getting power then the only link between it and the distributor is the one wire...sooo that narrows it down pretty good.
Old 10-16-2007, 03:07 PM   #7
dapaur's Avatar
can i use any coil plug wire?
Modified by dapaur at 6:58 PM 10/16/2007
Old 10-16-2007, 04:18 PM   #8
slamdlude's Avatar
If you know that you are getting power to the coil but not beyond that my suggestion would be to go to the nearest parts store and buy a new coil and set of plug wires for the H23 that you just put in and install them. The wire set should come with a coil wire. So that solves the coil wire question also. Do you have a multi meter? check and see how much power is going to the coil, if any.
slamdlude is offline   Reply With Quote
Old 10-16-2007, 04:47 PM   #9
1fastlude1's Avatar
Default Re: prelude ignition help!!! (slamdlude)
just cause there is power doesnt mean any thing one side should be pulseing.
1fastlude1 is offline   Reply With Quote
Old 10-18-2007, 07:58 AM   #10
dapaur's Avatar
Default Re: prelude ignition help!!! (1fastlude1)
alright if the power dont pulse where should i check imabout to run out to it now and the coil worked it came from a motor that had spark but no compression
Old 10-21-2007, 11:28 AM   #11
dapaur's Avatar
bump
Old 10-24-2007, 09:48 AM   #12
dapaur's Avatar
bump
Old 10-24-2007, 11:05 AM   #13
ChrisRicketts's Avatar
sounds to me like the coil may be bad. i know you said it worked before, but i've done the same thing before-- changed motors and car wouldn't start, ended up being the coil. make sure ALL grounds are secure (frame rail to engine, ecu to head under thermostat, driver's shocktower to valve cover/powersteering pump). They ALL are necessary. I've left the ground loose on the driver's side before and the car wouldn't crank. I'd try changing the coil if all the grounds are good, i don't think they are that expensive. If you accidently tried cranking the car with the coil plugged in without the coil plug wire being connected to the dizzy, that could have shot your coil. (maybe you checked compression in the motor with coil plugged in, but just took the plug wire loose instead of unplugging the coil altogether is what i'm saying).
ChrisRicketts is offline   Reply With Quote
Old 10-24-2007, 01:22 PM   #14
dapaur's Avatar
Default Re: prelude ignition help!!! (ChrisRicketts)
alright i used external coil stil no spark so still unsure about coil
but there are 3 wires going to coil there positive neg and tach the positive lights up the negative i am told should surge when i connect test light to it and the key is in the on postion the test light filment just glows when i go to start it goes out
so where do i go from here all my grounds are connected the one from battery to tranny from shock tower to motor and under thermostat to fuse box (i was under assupmtion)
and what could cause the ground not to surge?
Old 10-25-2007, 12:46 PM   #15
dapaur's Avatar
to the top
Old 10-25-2007, 08:05 PM   #16
Hawkze_2.3's Avatar
What?
Old 10-25-2007, 08:22 PM   #17
dapaur's Avatar
i was explained liek this the coil has a power ground tach going to it the power is constant and the ground flashs on the off basically floods the coil then nothign then floods it get it
when i asked the guy who said the coil ground flashs he told me there something wrong with the module where can i find this could this be it etc
Old 10-25-2007, 09:32 PM   #18
slamdlude's Avatar
Have you gone to the store and bought a brand NEW coil and installed a NEW coil? From reading the post it doesn't seem like you have. until you buy a new coil you are probably just chasing your tail.
Modified by slamdlude at 9:51 PM 10/25/2007
Old 10-26-2007, 07:31 AM   #19
dapaur's Avatar
i used and external coil to see if it was the coil and still no spark i mentioned this and i know the external coil works and there is no surge in the ground to the coil so the coils not gunna work what cause it not to ground
Old 10-26-2007, 07:54 AM   #20
ok.....i could be completely wrong here, but i don't think that a ground surges. A ground is GROUNDED. check the voltage coming from the thick yellow wire, you should be getting 12v (as you said you were). So, now that is out of the way, we know you are getting power to the coil....now we need to have the power get to the dizzy.
IF YOU HAVE POWER TO THE COIL, (AND THE COIL WORKS), THEN THE COIL WILL POWER THE SPARK TO THE DISTRIBUTOR.
The only thing that I see in this scenario (whether you like it or not, or agree or disagree) is that the coil is bad. It happens a lot, it's not uncommon, I've had it happen twice.
CHANGE THE COIL!!!
If it doesn't work then, come back and post and we'll trouble shoot some more, but till then, I believe that's your problem. If it's not, take the coil back to the store and get a refund- tell them you didn't need it after all. Then you are out nothing.
Old 10-27-2007, 10:28 AM   #21
dapaur's Avatar
bump
Old 10-29-2007, 12:54 PM   #22
dapaur's Avatar
to the top
Old 10-29-2007, 02:08 PM   #23
are you going to continue asking until you get an answer you like? have you even tried using a different coil yet? if not, then you shouldn't bother continuing to ask people on here for what your problem is. if you change the coil and it doesn't work, then you can come on here and laugh in my face and tell everyone how stupid i am and how you wasted 4 minutes of your life changing the coil.....so its a win-win situation if you change it.
Old 10-29-2007, 04:29 PM   #24
slamdlude's Avatar
x2
Old 10-29-2007, 06:50 PM   #25
dapaur's Avatar
read i used and external coil it still did not work its the same difference changing a coil and using and external coil next time why dont you read instead of trying to get on me i just want to know what to do so i can get him on the road
car wont start ..spark ?? EFjoe91 Honda CRX / EF Civic (1988 - 1991) 13 11-25-2015 06:02 AM
GSR fuel but no spark GoSickemRobert Engine Management and Tuning 2 08-03-2011 12:07 PM
I have 93 prelude it wont spark lmgskater Honda Prelude 6 12-21-2008 11:28 AM
New Dizzy, New coil, No F-N Spark ! NeKe1point0 Honda Accord (1990 - 2002) 14 01-21-2008 07:07 PM
HELP!!! NO SPARK!!! Red Wing Honda Prelude 4 01-01-2002 05:58 PM
Tags
95, coil, dizzy, external, fuel, ignition, lude, power, pre, prelude, run, spark, windows, wireless, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
