power steering belt
power steering belt
is there any tutorial or guide on how to tighten the tension of the power steering belt. or how to replace one. because i pretty sure my power steering belt is going bad. screetches when i start up and sometimes when i take a turn.
Re: power steering belt (digitalh3lix)
The PS pump is the EASIEST accessorie to adjust.
Losen the bolts that hold the PS pump to the bracket. Then, tighten the adjustment bolt on the top of the PS pump (the long bolt that attaches to the PS pump and the bracket)
When the tension is tight, tighten the bolts that hold the PS pump to the bracket.
Hope this helps.
Andy
Hope this helps.
Andy
