Popping sound when turning/going over large bumps
Old 03-25-2007, 10:48 AM
rocket30004's Avatar
Default Popping sound when turning/going over large bumps
So here in MI the roads are pathetically bad. Went over a fairly large pothole at speed the other day. Since then when I turn (left only) I hear a popping sound on ocassion NOT all the time, and a similar sound when going over bumps.
Normally ppopping while turning = bad CV joint, but it's more of a pop than a click sound, and is sporadic not constant (just one pop overy once in a while, not a constant click-click-click-click every time I turn --- which is what I experienced when I had a bad CV joint in my old civic).
Could it be a ball joint or something? How do I diagnose it as a bad CV vs. something else?
Thanks
Old 03-25-2007, 10:55 AM
GraphiteMW's Avatar
Default Re: Popping sound when turning/going over large bumps (rocket30004)
It can be the CV axle, the first few months of my CV axle going bad it would only make noise if I get on a dirt road or go over speed bumps then it worsen to having the knocking/clicking sound while I accelerate and take turns. So replace to the CV axle to be safe.
Check your CV boot for rips or lots of grease, that means its going bad.
Old 03-25-2007, 11:20 AM
Aahj's Avatar
Try checking your balljoints and sway bar endlinks.
AJ
Old 03-25-2007, 12:06 PM
britishdude's Avatar
Default Re: Popping sound when turning/going over large bumps (Aahj)
My swaybar endlinks caused exact similar noise, found wear and replaced all okay now.
Old 03-25-2007, 12:43 PM
andre809_lude's Avatar
Default Re: Popping sound when turning/going over large bumps (britishdude)
upper ball joints!!! i had the same..
Old 03-25-2007, 04:44 PM
Default Re: Popping sound when turning/going over large bumps (andre809_lude)
Thanks for the responses
I hope it's not a CV slowly going bad...
But, if it is a swaybar endlink and/or ball joint, what am I looking for to see if it is "bad". Does the swaybar link have a boot and joint like a ball-joint? Should I just look to see if it is ripped/torn/etc. or is there another/better way to diagnose?
Old 03-25-2007, 05:30 PM
GraphiteMW's Avatar
It has rubber mounts on them, check for deteriation/cracking
Old 03-26-2007, 10:18 AM
Default Re: Popping sound when turning/going over large bumps (GraphiteMW)
I didn't get a chance to inspect anything yet, but I did notice that it does the sound when it is neutral and in gear... not sure if that helps w/ diagnosis, but I clearly remember that on my civic, it made the clicking sound from the CV joints only when in gear.
I'll check try and get under there today/tomorrow and see whats up... thanks again guys!
Old 03-26-2007, 02:56 PM
MooJenLude's Avatar
Check all the boots you can possibly see. Jack the car up and take off the wheel inspect closely because even a small tear can be a bad one. If any of the linkage/joints has/have a grease fitting you might want to grease it.
Old 03-31-2007, 09:51 PM
Default Re: (BurberryLude)
Well, got a chance to poke around today
On the pass. side, the end-link was broken/disconnected, so it needs to be replaced.
Haven't found a write-up (or even where it is in the FSM) but looks like it should be easy.
Anyone have a link to a write-up or page # in FSM?
PatrickGSR94
Suspension & Brakes
19
11-29-2008 06:09 AM
riceforlife
Suspension & Brakes
13
12-12-2007 11:27 PM
B00ST2nR
08-06-2006 06:32 AM
pho iz good
03-18-2005 04:48 AM
amolm
20
01-04-2005 08:22 AM
Quick Reply: Popping sound when turning/going over large bumps
