Overheating, where to start
My prelude keeps over-heating, I have no idea where to start. It overheated so much that it busted one of the coolant hoses behind the block. I need it fix it asap. Any ideas?
Re: Overheating, where to start (Kronn 98SH)
if it overheated real bad I would look into the head gasket and make sure u didnt warp the head
was there any smoking or leaks prior?
Re: Overheating, where to start (teefunk01)
no, smoking from under the hood, and I haven't noticed any leaking. It's heavily modified, boosted, etc.
Re: Overheating, where to start (jaywoodz)
Check:
Turn on AC and make sure fans are turning on.
Coolant levels
Leaks in the hoses or anywhere else (might be pinhole sized)
Thermostat (When your car gets to operating temp turn off the car and feel if bottom hose is cool)
Grounds (that's if you're not really overheating but it seems you are)
Bleed for air in the system through nipple by thermostat
(thanks Giant_Bean really worked for me)
Someone correct me if I'm wrong on any of this. It's just what I've gotten from reading around.
Coolant levels
Originally Posted by Giant_Bean
I have found that the best way to get all the air out of the system is to park on an incline or jack the front end up, so that the radiator cap is the highest point of the cooling system, remove the cap and run the car for a few minutes. After that replace the cap, let a little pressure build up, and open the bleeder nipple and check for air.
runwitme
14
05-17-2009 04:16 PM
