Old Gas
Old Gas
I pulled an A4 motor from my '99 lude about two years ago. It was supposed to back in right away, but it turned into a side project and is just about to go back in. What would you recommend doing with the old gas? Should I dump a bottle of seafoam in it, or do I have to siphon it all out? What about the filter and that, do they need to be replaced? The other lines, tank,...........
Re: Old Gas
I would take the tank completely off and dump the old fuel + clean the insides. No need to really worry about the lines. Get a new fuel filter, I would also get a new fuel pump while you have everything apart.
Re: Old Gas
If there is not too much gas left, you can put some HEET in the tank and fill it up with premium. If there is a bunch of gas in there, then siphon some out first. Change your fuel filter after you run it if you want to.
My prelude sat for a couple years and that's what I did. No problems with the fuel pump so no need to change it out.
Re: Old Gas
BTW - There is a drain plug on the gas tank. On a fifth gen it is located on the drivers side (LH) rear corner.
Tim Manhattan
04-21-2012 08:48 PM
severs
06-27-2007 01:48 PM
