Is it okay to run straight distilled water?
Old 07-12-2014, 07:55 PM
AudioFunk's Avatar
Default Is it okay to run straight distilled water?
Just water no coolant ?
Old 07-12-2014, 09:14 PM
Kiritch's Avatar
Default Re: Is it okay to run straight distilled water?
U R crazy, I'm serious. Do this, and you'll say "good bye" soon to your water pump.
Coolant is not so expensive to save on it.
Old 07-12-2014, 11:06 PM
holmesnmanny's Avatar
Distilled water is not a big deal at all for temporary use. You just dont want to use tap water. When you get a chance just drain and fill with 50/50 and youll be fine.
It would be best after using distilled water to do a 50/50 drain and fill, open the heater valve and drive around for a bit and do another 50/50 drain and fill tho.
Old 07-14-2014, 07:55 AM
Moderator
snobordboy's Avatar
If you don't have any fear of freezing temps, distilled water is just fine, or add a bottle of Redline Water Wetter to the water.
Old 07-14-2014, 01:15 PM
jsalas623's Avatar
Id highly suggest you dont do that. Next time try touching the radiator fluid you put in your car. It will feel a little oily and that is to protect any moving parts from waring out or worst yet rusting. You can do it as a temporary thing but I wouldnt be running on water alone.
nonvtec92
11
04-30-2008 02:45 PM
Obama
06-20-2007 07:10 PM
Osokwik
02-22-2004 08:45 AM
Driven
51
08-17-2002 09:19 PM
siisgood00
21
10-18-2001 01:14 PM
Quick Reply: Is it okay to run straight distilled water?
