The official H/F piston/rod/crank/block specs and CR thread
Old 05-04-2005, 03:43 PM
  #26
H22Si's Avatar
Default Re: (Innovation)
bore spacing?
awesome thread
Old 05-04-2005, 04:40 PM
  #27
Innovation's Avatar
Default Re: (H22Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Si &raquo;</TD></TR><TR><TD CLASS="quote">bore spacing?
awesome thread </TD></TR></TABLE>
I thought about adding that but since its the same for all F/H motors I figured its best left out of the thread... I didnt think it was much of a need to know type spec...
Old 05-05-2005, 06:04 AM
  #28
ZigenBallz's Avatar
The F22Ax & F22B1 VTEC both have 34mm Int valves & 29mm Exh valves if I remember correctly...
While the...
F22B2 has 32mm intake valves and 29mm exhaust valves...Strangeness I know...
and even though numerous sources list the F22Ax heads as having 50.5cc chambers they in reality have 50cc chambers...
and if I might be so bold as to request the addition of the F22B DOHC, the F20A DOHC and the F20A SOHC...
Add em and I'll send what info I have on em...
for the thread though.... it's about time someone made a good solid repository of this info...
Modified by ZigenBallz at 8:21 AM 5/5/2005
Old 05-05-2005, 06:58 AM
  #29
Innovation's Avatar
Default Re: (ZigenBallz)
Post up whatever info you have on the F20A/F22B DOHC's and ill add them
Old 05-05-2005, 11:19 AM
  #30
Innovation's Avatar
Added F20B valve specs
Old 05-05-2005, 12:40 PM
  #31
machine4321's Avatar
thanks fo rthe f20 specs.....i guess h23 valves would work?
Old 05-05-2005, 12:53 PM
  #32
Innovation's Avatar
Default Re: (machine4321)
stem heights are going to be different
Old 05-06-2005, 04:07 AM
  #33
thought about that after i posted..dammit lol
Old 05-06-2005, 05:06 AM
  #34
2lude4u's Avatar
Default Re: (PirateMcFred)
Can anyone post how compression ratios are affected by various alterations like thinner/thicker head gaskets, milling the head, etc. I know this is depends on which motor/head your dealing with, but if you can at least put the calculation method in the main post it will be helpful.
I'm sure someone has it memorized, but if not I'll have a look at my books tonight and see if I can post it.
Old 05-06-2005, 05:58 AM
  #35
2lude4u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=438456
Pirate</TD></TR></TABLE>
Thanks, very informative.
Old 05-06-2005, 10:35 AM
  #36
Innovation's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">Hey rick, This One did a boosted F20 Build and he had his CC measured. He said in his thread it was ~54cc's so I would guess that it is 53.8cc</TD></TR></TABLE>
I have that head getting cc'd aswe speak... Ill post up results by the end ofthe week
Ill take a look at flyrod's thread in a few minutes, thanks
edit:
I will have dome volume specs for USDM H22, JDM H22, F20B and F22 pistons soon... Jdogg is taking a trip to RLZ to have magic man Brad Z cc everything
Im gonna hold off on calculations untill everything gets cc'd, giving definitive specs for the most accurate calculations...
Old 05-06-2005, 01:21 PM
  #37
mgags7's Avatar
"with this information i will be able to build the ultimate honda block"
as he taps his fingers on the keyboard menacingly.....
wow now im sorta regretting saying all that....
anyways....good info....
Old 05-07-2005, 10:55 AM
  #38
prelittlelude's Avatar
Default Re: The official H/F piston/rod/crank/block specs and CR thread (Innovation)
rick you listed the f23a1 as 1.181 compression height, could one assume this is for all f23ax?
edit:
agian rick i wanted to mention the f20c , pretty much disreguarding the head but the pistons are high compression forged frm compatable with a relatively short compression height
also the 04+ f20cs have a 90.7 stroke witch means the rods could be of some use
also the 00-03 have a 84mm stroke and the rods could be possibly used in a hybrid setup..
also the f20c pistons have a 87mm bore and they have the same pin diameter as the other motors mentioned here as well as if my memory servers me right has a usuable big end bore of the rod, meaning it is the same as atleast one fot he motors listed here i just don't remember which.
Old 05-07-2005, 10:58 AM
  #39
Innovation's Avatar
Default Re: The official H/F piston/rod/crank/block specs and CR thread (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">rick you listed the f23a1 as 1.181 compression height, could one assume this is for all f23ax?</TD></TR></TABLE>
I would say its safe to assume so, there arent any variations in the stroke, rod length or deck height between the different F23's... It would be kind of odd if there was actually a difference in compression height ::shrugs::
Old 05-07-2005, 11:37 AM
  #40
well just so i have a one stop shopping spot im going to put the f20c info up
99-03 86mm stroke
rod
155.65mm lenght
BE bore is 2.008
piston
04+ 90.7 mm stroke
rods probably same spec as h22a4
Old 05-08-2005, 12:07 PM
  #41
JDogg's Avatar
according to my info the f20c has a 153mm rod and the f22c has a 150mm rod
h22 has a 143mm rod
Old 05-10-2005, 07:46 AM
  #42
The_Head's Avatar
subscribe to thread
Innovation
Are you going to make a compression calculator for the H/F series motors?
&lt;----- willing to help out if there are any monetary requirements
Old 05-10-2005, 08:08 AM
  #43
Innovation's Avatar
Default Re: (The_Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">subscribe to thread
Innovation
&lt;----- willing to help out if there are any monetary requirements</TD></TR></TABLE>
If anyone wants to make one based on the information provided in this thread... Be my guest
Ill help with whatever I can to make it happen
Old 05-19-2005, 10:42 PM
  #44
spirit7627's Avatar
Anyone know the deck height of the F20c ?
also the rod width and, if the F20/22c have the same piston compression heights?.
Next ; does anyone know the dome cc's for the F22b/F20a ( dohc & sohc ) and, F20z ? Do the all ( F20 a vs F22b) have the same piston compression height ?
That's been bugging me for 2 years. Just came back from a 4 month stay but, did not have time or resources to find that info...
Old 06-16-2005, 08:25 AM
  #45
Sam1am26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Innovation &raquo;</TD></TR><TR><TD CLASS="quote">
Ill cover all and everything you ever wanted to know about crank/rod mods/swaps and secrets in another informative thread similar to this one... I should have that up by the end of next week...
I have a crank mod/rod swap thread in the works that will answer all your questions and then some... That will be the first of several write ups and projects I have coming up for the prelude forum...
Whatever happened to this???
Old 06-16-2005, 08:38 AM
  #46
Innovation's Avatar
Default Re: (Sam1am26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote">Whatever happened to this???</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1245350
https://honda-tech.com/zerothread?id=1245658
Ive been extremely busy lately, If I had the time to do more in terms of tech articles and write ups I would... Im just spread super thin as it is.
Being a dad, being in a relationship, business ventures and projects keep me pretty tied up now adays
Old 06-21-2005, 05:23 PM
  #47
Innovation's Avatar
Default Re: The official H/F piston/rod/crank/block specs and CR thread (suprfast)
F22 and H23 cranks are identical, same exact part number from Honda... Same goes for the rods
Old 07-09-2005, 11:30 PM
  #48
Sille98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">Hey rick, This One did a boosted F20 Build and he had his CC measured. He said in his thread it was ~54cc's so I would guess that it is 53.8cc:
https://honda-tech.com/zerothre...64205
Ya he found out some good info. This thread should be a sticky Awesome Info...
Old 10-18-2005, 10:04 PM
  #49
hybrid_vtec's Avatar
good info!
Old 10-18-2005, 10:27 PM
  #50
mgags7's Avatar
back from the muerto...but yes it is good info
anyone with the missing piston specs chime in
Quick Reply: The official H/F piston/rod/crank/block specs and CR thread
