innovative alternator relocator help
i just installed the innovative alternator relocator on my h23 and have the issue of the belt rubbing against the plastic timing cover...any ideas? i'm sure it's in the correct spot, don't know if it's a flaw with my particular mount or if i'm doing something wrong. thanks for any help.
Re: innovative alternator relocator help
looks good brian.
since i spy a bolt missing holding the timing cover on, are you sure its not missing a couple more, making the cover not seated properly??
i believe it is the balance shaft, on the bracket there are two sets of holes: one set for running the balance shaft and to the right for no balance shaft. innovative is closed on sat and sun so if i can't figure it out soon i'll give them a call on monday.
waciii
04-11-2011 11:34 PM
alternator, belt, bracket, cover, h22, h22a, h23, innovative, mount, prelud, prelude, relocater, relocation, relocator, rubbing
