not another no start ?
yep, it's another no start question. my car cranks but just won't start. the fuel system is good i think since i can hear it prime when i turn on the power. the battery is new, the spark plugs are new. the starter will only crank when i try to jump it. coil is good (i tested with a new one). ignition module connections are good (i tested using helms). ignition wires are good (tested with helms). what else. i guess that's it. i'm gonna replace the cap and rotor tomorrow. so what else is there? what can cause a crank but no start problem?
btw, i don't know if i checked for sparks correctly. i didn't see any sparks but i can smell fuel on them. these are new spark plugs too. so what's going on? am i doing the test wrong? let me try to get this right. take out the plug, hook it back up on the wire as normal but out of the engine, touch it to ground, crank the engine and look for a jump? maybe someone can show me the correct way to check for sparks?
thanks in advance!
thanks in advance!
Re: not another no start ? (joblow)
try replacing your cap and rotor. I had this problem a while back and it turned out that the center electrode on the cap wasn't making contact with the rotor. It would crank but it wouldn't start. Anyway, good luck!
Master H Technician
my car cranks but just won't start. the starter will only crank when i try to jump it.
thanks in advance!
thanks in advance!
C-West Civic
06-06-2017 05:40 PM
