No Vtec.. has my solenoid gone bad on my H22???
Nothing happens when 12volts applied to solenoid. I noticed that I dont feel vtec kick in so I decided to check the solenoid at Idle. When I powered it up there was was no change ( normaly the engine would bog and die). Do vtec solenoids go bad or could it be something else?
Re: No Vtec.. has my solenoid gone bad on my H22??? (jetlude)
it may not be the solenoid.
Check if you're oil level is at the right point.
Or you may have the same problem I had.
If your speed censor doesn't work then your vtec wont engage.
Hope this will help
Hope this will help
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetlude »</TD></TR><TR><TD CLASS="quote">Nothing happens when 12volts applied to solenoid. I noticed that I dont feel vtec kick in so I decided to check the solenoid at Idle. When I powered it up there was was no change ( normaly the engine would bog and die). Do vtec solenoids go bad or could it be something else? </TD></TR></TABLE>
take it off and clean it first. But if it doesnt activate after giving power to it, then its likely the culprit.
Re: No Vtec.. has my solenoid gone bad on my H22??? (98vtec)
yeah if ur not getting any reading from it then shes shot or the wiring chances are the solenoid.
best thing to do is take i off of the motor and test it on a bench. that way you can be sure your giving it 12v and ground
jetlude
02-06-2007 05:59 PM
