New starter grinding On the Flywheel - Honda-Tech
Old 07-01-2004, 01:42 AM   #1
g2homboi's Avatar
Default New starter grinding On the Flywheel
Okay I've just helped my friend install a new starter in his 93 Prelude, we thought it was the starter but ended up being the battery, so we kept the starter. The problem is now the starter grinds when we start the car. It does it for at least 2 seconds then stops. My question is should we replace the starter, with the starter it originally had, or is it safe to let it grind everytime the motor starts, and you can give me any other advice to fix the problem. By the way I do not know what flywheel he has installed, since he just bought the car. Any help would be appreciated.
g2homboi is offline   Reply With Quote
Old 07-01-2004, 01:58 AM   #2
@ries's Avatar
Default Re: New starter grinding On the Flywheel (g2homboi)
The ring gear on the flywheel might have moved. Try inspecting it through the hole between the tranny and the block... it's a small rectangular plug.
Modified by @ries at 3:24 AM 7/1/2004
@ries is offline   Reply With Quote
Old 07-01-2004, 02:04 AM   #3
g2homboi's Avatar
if it's moved, is it possible to fix it without tearing out the tranny?
Old 07-01-2004, 12:45 PM   #4
g2homboi's Avatar
bump..
Old 07-01-2004, 01:10 PM   #5
Banned
Default Re: (g2homboi)
A couple things:
Take the starter out and very carefully compare the teeth to the old starter.
Unless you're positive you bought the right starter, take it to another store and compare it to another starter for the same car.
And like you said, the flywheel is suspect... but since the old starter worked you know at least those teeth match.... so compare the old and new starter before ripping the engine apart.
kb58 is offline   Reply With Quote
Old 07-02-2004, 03:19 AM   #6
g2homboi's Avatar
i actually examined it before installing. I notice they were different before I installed the new starter. The new one sticks out a little bit more than the old. Thanks for the advice everyone.
Old 07-02-2004, 12:27 PM   #7
LudeyKrus's Avatar
Replace the starter w/ the original one, take the new one back to the store for a refund, and don't mess with it anymore.
LudeyKrus is offline   Reply With Quote
95 accord wont start rkmartin017 Honda Accord (1990 - 2002) 9 07-21-2012 08:34 PM
Eg b20b starter problems akllls Honda Civic / Del Sol (1992 - 2000) 6 08-16-2011 09:45 PM
90 crx starter problems robot.reed.o Honda CRX / EF Civic (1988 - 1991) 7 03-11-2009 07:33 AM
weird start up problem? not the starter! DC4 Rasta Acura Integra 2 08-30-2007 11:38 AM
HELP!!! problem with starter turning but not starting my car classciv Honda CRX / EF Civic (1988 - 1991) 7 12-18-2005 12:53 PM
Tags
98, fixed, flywheel, grindin, grinding, honda, prelude, ruined, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
