new auto tensioner kit
Just wandering if any one has any experience with the newer improved auto tensioner kit from honda. The part number is 06144-P13-305. Im assuming it would be better off then the original ones, which are known to fail. Just need some clarification. Also when replacing the belt on an h22a. is there a tensioner pulley that needs to be replaced also besides the timing belt, and auto-tensioner? Or is it just those 2.
peace,
peace,
Re: new auto tensioner kit (iwhichisme)
I would recommend going with an H23 manual tensioner assembly.
otherwise the kit is the t-belt and the autotensioner itself..I don't think it would include the pulley. you should also be doing your water pump
Re: new auto tensioner kit (satan_srv)
yeah ive heard of a lot of peeps going to the manual tensioner. But from what i understand; The kit comes with an auto-tensioner that was suppossed to be an improvement. I did intend on changing the water pump as well as the pulley also. Yeah i know the kit doesnt include the pulley, just found that out like a sec ago. thanx for the help guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">I would recommend going with an H23 manual tensioner assembly.
otherwise the kit is the t-belt and the autotensioner itself..I don't think it would include the pulley. you should also be doing your water pump</TD></TR></TABLE>
agreed
agreed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme »</TD></TR><TR><TD CLASS="quote">how long have you had it on yours? already done a search.</TD></TR></TABLE>
17k miles with the new auto-tensioner. But 164k before that with no probs. However, my setup is stock now. I will not be trusting the auto after changing head/cams.
Re: new auto tensioner kit (Quick99Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick99Si »</TD></TR><TR><TD CLASS="quote">What are the symptoms of an out-of-spec timing belt tension?
Adi</TD></TR></TABLE>
tension? Slapping.
tension? Slapping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme »</TD></TR><TR><TD CLASS="quote">yeah ive heard of a lot of peeps going to the manual tensioner. But from what i understand; The kit comes with an auto-tensioner that was suppossed to be an improvement. I did intend on changing the water pump as well as the pulley also. Yeah i know the kit doesnt include the pulley, just found that out like a sec ago. thanx for the help guys</TD></TR></TABLE>
if you're stock sure I guess....but how many times must it fail before you switch? It's slightly more expensive I think I haven't looked up prices lately but I got mine off an old h23 for $40...peace of mind
yeah i here ya, my plan was to go with the manual setup, but a freind of mines got the the auto tensioner/ timing belt kit for pretty much nothing. so i figured id give it a try. If it fails, "manual here i come!!"
Re: new auto tensioner kit (BioXide02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BioXide02 »</TD></TR><TR><TD CLASS="quote">How often do you have to adjust the manual one? </TD></TR></TABLE>
I was running a power enterprise super strong belt..so never
I was running a power enterprise super strong belt..so never</TD></TR></TABLE>
Okay, well lets say if you where running an OEM belt?
