Need timing help!!!
Need timing help!!!
First of all I have a JDM H22a in a 97 civic. Yesterday I changed out my timing belt and balancer belt. So I drove my car last night and I have a huge loss of power. I think it is the rear balancer pulley. In the book it says you are supposed to stick a bolt through the maintenance hole to align the rear balance shaft and rear timing balancer pulley. When I did it I was able to position the balance shaft and rear timing balancer pulley in three different positions.
There is a timing mark on the rear timing balancer pulley, where should this timing mark point?
1 Post
Re: Need timing help!!! (BolisticSi)
Honestly I would just remove the balance shaft belt and see if your problem goes away. You won't miss the balance shafts anyway...
Re: Need timing help!!! (Hawkze_2.3)
If they werent needed dont you think honda wouldent have incorporated them into the design of the motor ?
Align all your timing marks again and check to see if you are of a tooth or two.
1 Post
Re: Need timing help!!! (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">If they werent needed dont you think honda wouldent have incorporated them into the design of the motor ?
Align all your timing marks again and check to see if you are of a tooth or two.</TD></TR></TABLE>
They're just for comfort as they eliminate vibrations. People remove these all the time, there are even balance shaft eliminator kits with lots of R&D behind them that have sold probably hundreds of units. I see no problem in removing them other than vibration...
Yep the balance shafts are just for NVH(noise vibration harshness) mostly used on Inline 4 bangers over 2.0L
Ef4doorwagon
17
08-30-2014 11:58 PM
chromeBuddha
08-04-2008 12:43 PM
