Need some help on my recent swap...
So My h23 block blew, so i had to swap in a F22a4 for the mean time so i can drive it around, I heard that the F series and the H series are interchangable, So I did that, I have the h23 Intake manifold on the a4 and the alternator etc.. But I tried putting the h23 belt for alternator because the alternator is from the h23. But it is too loose... the i tried the f22 one, and it was loose? Is it the H23 Bracket that could be the problem? do i need the F alternator bracket? because it might extend out further..?>
Re: Need some help on my recent swap...
IN other Words, Are all the H23a1 parts interchangable with the F22a4 SOHC, I hear it is, but The alternator is confusing me....
buy a new belt.
use a piece of rope/twine/string to measure the length. get one same length at auto parts store.
install.
have a beer.
install.
have a beer.
I sure hope so, SO measure it with a rope and then take it to the autostore. okay.. I'll try tat.. but do you know which specific spark plugs go where?
And do you mean you mean spark plug wires? You can do a search for firing order pretty easily. I recommend buying a Factory Repair Manual if you plan on doing much work to this car.
Might also want to try spell checking your post before hitting the post button. Seriously. Makes a lot of people frustrated and not help.
