need help with removal of crankshaft pulley on h23
I do not have a air compressor and do not know where to buy the 50mm holding tool.I must not turn the crankshaft while at top dead center.The car is an automatic and i need some advice,thanks
Did you try searching google? I searched "Honda crank pulley tool" and got a ton of hits:
http://www.amazon.com/Alltrade...TMLWQ
http://www.etoolcart.com/brows....HTML
http://shoptoolsshoptools.com/...Tools+
http://www.moroso.com/catalog/...27115
I use the Honda tool myself, but I have the one listed in the first link too.
IIRC, the H23 crank pulley is a bit more difficult to get off because the hex is a bit chamfered. I had to modify my tool (the one in the first link) to get it to fit snugly. My OEM Honda tool fits in the H22 and Euro R crank pulley just fine.
Re: (saikou)
Good link,I was wondering if there were any tricks to cheat because I really need to get this fixed today,I have already missed two days of work now because of this
Re: (frostwhite si)
i tried getting that bolt out for about 3 weekends by wedgning screwdrivers into the flywheel, putting the car on the ground and standing on the brakes, basically everything imaginable to prevent the engine from turning
as soon as i got the crank pulley holder tool, i had it off in 5 minutes
just buy the tool, and have it delivered like 2nd day
1 Post
Re: (frostwhite si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frostwhite si »</TD></TR><TR><TD CLASS="quote">Good link,I was wondering if there were any tricks to cheat because I really need to get this fixed today,I have already missed two days of work now because of this</TD></TR></TABLE>
If you need it done now now now, what I did with mine was take it to a local shop and have them hit it with their big impact real quick. Then you can use a wrench to just manually tighten it for the short (hopefully) drive home and then you'll be able to loosen it again at your house.
Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 »</TD></TR><TR><TD CLASS="quote">Did you try searching google? I searched "Honda crank pulley tool" and got a ton of hits:
IIRC, the H23 crank pulley is a bit more difficult to get off because the hex is a bit chamfered. I had to modify my tool (the one in the first link) to get it to fit snugly. My OEM Honda tool fits in the H22 and Euro R crank pulley just fine.</TD></TR></TABLE>
can someone confirm which one actually fits on an h series...this on says 92 and later on the package:
http://www.amazon.com/gp/produ...img=1
but this website lists 2 different eom part #'s: 07MAB-PY3010A for sohc and 07NAB-001040A for dohc.
http://www.hondalac.com/servic...e.pdf
is the alltrade tool one size fits all?? and does anyone know why there are 2 different holders for sohc and dohc???
Re: (gogunkergorilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gogunkergorilla »</TD></TR><TR><TD CLASS="quote">
thats the EXACT one that i have. even got it on amazon
SobrietyRulesNA
01-11-2015 10:01 AM
