Need help with h23a1 stalling while driving down the road
Need help with h23a1 stalled while driving and wont start
Has knock sensor code,its getting fuel ,not sure if its an ignition switch or distributor,any advice would be appreciated,it stalled a couple times before but would restart now it wont
Modified by frostwhite si at 5:56 PM 6/26/2007
Re: Need help with h23a1 stalled while driving and wont start (frostwhite si)
start with the basics, spark, fuel pressure, timing.....and fix the knock sensor, red/blu to D3 on ECU
It's your knock sensor. Let me guess, you notice it the most from 2k-3.2k RPM. The knock sensors have a tendency to come loose from the rear of the block. Do a search on it, a lot of people have had the same issue, including myself. In my case the little plastic clip holding the sensor in place is very temperamental, and had just not been plugged in all the way. I'd try plugging this back in if it slipped out, and if it is actually a bad sensor, go ahead with replacing it as this will cause your hesitation that will feel like you're bogging/stalling out.
