need engine connector pinouts
hello i am looking for pinouts for the shock tower connectors ; c133, c134, c135 m/t, and c136 i have only found limited info maybe some who works at honda could help me out i have a shop manual but it doesnt tell me pinouts and neither does alldata or mitchel on demand i am in desperate need of this info thanks in advance!
Re: need engine connector pinouts
Those are the connections that go into the cabin. c133 connects to C425, c134 to c426, c135 to c432 and c136 to c433.
yes i need to know where the wires go from those connectors. i am doing a h22 crx im using a dash wiring harness from a prelude and i shrunk it down to just the data wires going from the ecu to the engine i just have wires that dont go to the ecu that im guessing either go to power or ground for sensors i have about 12 wires that go to those connectors but not to the ecu and i need to know where they go.
k blue connector not engine side and blu/wht, yel/blk, yel/red, blu/red, blk/yel, yel/wht, and red oh and just strait blue too
the red wire is the ect gauge sending unit.
blue wire goes to the dizzy its either tdc/ckp/cyp( its part of the two wire connector the other wire in the connector is a thick yellow wire)
Yellow/white is one of the wires in the tps
blk/yellow goes to the junction box in the bay
yel/red is oil pressure switch
yel/blk also goes to the junction box
blu/white i dont have a blu white...i have a white blu in that connector which is part of the alternator.
hopefully this helps a little
anything helps are you using a manual? if so would you be able to fax or send pics or post pics?
i have a torn apart harness that i took apart and labeled everything. Was working on it last week havent finished yet. I got some more answer hold up
EE_Chris
12-02-2003 06:05 PM
98AccordEX
10-02-2003 11:19 PM
untitled
09-14-2003 07:25 PM
