Need to confirm how to mark flywheel for ignition timing on H22A
Old 05-15-2007, 10:30 PM
pcguy760's Avatar
Default Need to confirm how to mark flywheel for ignition timing on H22A
I have an aftermarket flywheel in my H22A and it does NOT have the ignition timing marks so I am unable to set the ignition timing BUT recently I read that you can mark the flywheel with whiteout when you bring the No. 1 Piston up to TDC and you can use that whiteout mark to set your timing...
Can someone who has done this confirm with me this will work? Thanks.
Old 05-16-2007, 01:46 AM
TheWalrus's Avatar
spark timing is supposed to be 15 degrees before tdc...your talking about marking it at tdc
get a stock flywheel and see how many teeth the tdc mark is from the timing mark
Old 05-16-2007, 04:14 AM
pcguy760's Avatar
Default Re: (TheWalrus)
Anyone else who has done this before, can you confirm with me how to do this?
Old 05-16-2007, 05:43 AM
Propulsion's Avatar
Default Re: (pcguy760)
I've never done this before, but I would think, after you mark TDC as described,
# of teeth are on the FW = N
360 /N = degrees per tooth = D
So if you wanted 15 degrees,
15/ D = number of teeth you need to move away from TDC.
Old 05-16-2007, 07:05 AM
kulrevon's Avatar
Default Re: (Propulsion)
well you can mark it at TDC and just get a "good" timing light that is adjustable.
you should be able to get it within a few degrees. which I am sure is closer than what most people have theres set at.
Old 05-16-2007, 10:40 PM
pcguy760's Avatar
Hmmm that makes sense... but I need to confirm, so after I mark the flywheel at TDC, I get an adjustable timing light and then set the timing light to the recommended specs or whatever setting I want the timing to be (15 BTDC for H22?), and then I advance or retard the distributor until the TDC mark that I made on the flywheel, lines up with the arrow or pointer right??
Thanks.
Modified by pcguy760 at 9:50 AM 5/18/2007
Old 05-18-2007, 08:51 AM
pcguy760's Avatar
Bump to confirm lol
Old 05-19-2007, 08:44 PM
pcguy760's Avatar
Does anyone know if this is correct ^
Old 05-21-2007, 07:53 AM
pcguy760's Avatar
Default Re: Need to confirm how to mark flywheel for ignition timing on H22A (pcguy760)
Anyone?
Peter Brady onlyonweekndz
12-25-2007 11:18 AM
pcguy760
05-22-2007 09:50 PM
pcguy760
05-22-2007 07:01 PM
sheBangZ
09-02-2006 07:57 AM
Quick Reply: Need to confirm how to mark flywheel for ignition timing on H22A
