My 450hp 6th gen accord
First of all, I would like to thank Anthony at AV Engineering for all of his hard work on this one of a kind set-up! The car is a 6th gen Accord that was fully loaded from the factory so I wanted to keep everything as close to being a daily driver as possible. Anthony designed a custom top-mount AC/PS compatible manifold for the H series based on my set-up. The fitment is pretty tight but everything worked out better than I could have ever expected.
The car is a real monster on the street despite the heavy chassis. Traction isn't as bad as I would have expected since Anthony set-up the boost controller by gear/rpm through the sManager.
On 7.5psi the car made 283whp/230tq and 446whp/343tq on 17psi. The 446whp pull actually hit boost cut about 600rpm's early. Judging on other pulls Anthony said it probably would have made 460ish whp around 7600rpm. Either way, my original goal was 400whp so I'm more than satisfied and happy!
Here are the specs on the set-up:
Engine [*]AV Engineering Stage 2 Shortblock Package (CP/Eagle/Darton 300 sleeves)[*]Stock H22a Head/Valvetrain[*]AEM Adjustable Cam Gears
Fueling/Ignition[*]Precision 1000cc Injectors[*]Stock FPR[*]Walbro HP 255 Fuel Pump[*]Hondata s300 with boost control[*]NGK 3330 Plugs[*]Pump Gas[*]NGK Blue Plug Wires
Transmission/Drivetrain/Suspension[*]Quaife LSD[*]ACT 6 Puck Sprung Clutch[*]Tokico Illumina Adjustable Struts [*]Ground Control Coil overs with custom spring rates
Turbo[*]AV Engineering PS/AC Top-Mount Turbo Manifold[*]Precision GT35R SC6162e[*]Precision 600hp Intercooler[*]AV Engineering 2.5" Aluminum Intercooler Piping Kit [*]AV Engineering 3" V-Band Stainless Steel Downpipe[*]Custom 3” Exhaust[*]AV Engineering Oil Feed/Return Kit[*]AV Engineering Coolant Kit [*]Tial 38mm Wastegate[*]Tial 50mm Blow off valve
Pictures
Video (2nd movie down):
http://www.av-engineered.com/site/media/video
More pictures/specs here:
http://www.av-engineered.com/site/projects
Modified by strukaccord at 7:29 AM 9/26/2008
Pictures
Re: My 450hp 6th gen accord (ProjectBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectBB6 »</TD></TR><TR><TD CLASS="quote">That is awesome man . When is Anthony going to start selling those topmounts to us "real" luders lol? </TD></TR></TABLE>
You mean like this?
Fitment in the Prelude chassis is insane to keep AC. The downpipe runs down the side around the trans and to the exhaust. It is not a side-mount exhaust. If you guys think this is an innefficient design, then let the dyno charts speak for themselves:
AV Top-Mount vs. Brand X Ram-Horn
AV Top-Mount vs. Treadstone
AV vs. Drag
http://www.av-engineered.com/s...ested
Modified by PrecisionH23a at 3:49 PM 9/25/2008
You mean like this?
AV vs. Drag
Re: My 450hp 6th gen accord (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq »</TD></TR><TR><TD CLASS="quote">What about fitting this topmount in 5th gen Accord with AC and PS?</TD></TR></TABLE>
If you send us measurements from the head to the radiator core support we'll let you know. I would probably use the Prelude manifold for your chassis though.
