More Injector Help>? H22a same as H22a4>?4th gen/ 5gen Possible
Old 08-13-2003, 09:54 AM
caliriptide's Avatar
Default UPDATED. H22a same as H22a4>?4th gen/ 5gen Possible (FS) 3 injectors
Ok, I think I have the hookup on some injectors!!! SWEET! Heres the thing, the injectors are outta 5th gen/ Will they work in my 4th gen>??? I am running the P13, JDM H22 ECU. I did not know if the injectors would work. Ya know?/OBD1 , OBDII.
Thanx again!!
So can I get these injectors>??? for my prelude>?
H22 JDM 5SD
Modified by caliriptide at 3:29 PM 8/14/2003
Old 08-13-2003, 11:08 AM
Default Re: More Injector Help>? H22a same as H22a4>?4th gen/ 5gen Possible (caliriptide)
Anyone know>?
I also posted in the tec-post aswell.
Need info.
Old 08-13-2003, 11:49 AM
Behan's Avatar
the flow rates are different from 4th to 5th gen. if you look under the prelude stats and specs thread you will find what they are rated at. i'm pretty sure you could run them on the engine, but i know the flow rate is different
Old 08-13-2003, 03:00 PM
fastlude69's Avatar
Default Re: More Injector Help>? H22a same as H22a4>?4th gen/ 5gen Possible (93preludevtec)
also h22a are peak and hold and h22a4 are saturated so thats differenet and you will need a different resistor box
Old 08-14-2003, 04:28 AM
Default Update: More Injector Help>? H22a same as H22a4>?4th gen/ 5gen Possible (fastlude69)
Update/ I have good news-
I have found a complete set of JDM H22a injectors!
So up for grabs/ (3) H22a JDM injectors!
Any takers>?
taken offers?
OzWolfbane
01-11-2005 02:38 AM
caliriptide
08-16-2003 11:18 AM
crxste
05-21-2003 03:04 PM
Quick Reply: More Injector Help>? H22a same as H22a4>?4th gen/ 5gen Possible
